ams shifter bushing help?????
Old Sep 22, 2010 | 07:18 PM
Tims2006MR's Avatar
Ok so I'm in quite a predicament. I have Ams solid underhood ****ter bushings and the one that faces the firewall keeps popping the clip off I tried new Mitsubishi clips no luck. Have you guys ever seen this before???
Old Sep 22, 2010 | 07:26 PM
milford's Avatar
make sure the bushing is pressed in all the way. use a steel wire and run that through it and twist it up so it doesnt pop up if you have to
Old Sep 22, 2010 | 07:28 PM
Tims2006MR's Avatar
It does not have a hole their is a groove the clip rides in
Old Sep 22, 2010 | 07:30 PM
SLO-EVO's Avatar
that is where you are going wrong. The clip slides through a hole drilled through the pin...
Old Sep 22, 2010 | 07:33 PM
Tims2006MR's Avatar
I could not find a hole in their.
Old Sep 22, 2010 | 08:10 PM
Tims2006MR's Avatar
The one that faces the top has a hole but I fantastically find one in the one that faces the firewall
Old Sep 22, 2010 | 08:18 PM
06MRV8Killer's Avatar
They dont have holes in both, I had these in my car when I had the 6spd in and hated them but the clip should work properly, if not its an installation problem
Old Sep 22, 2010 | 08:23 PM
Tims2006MR's Avatar
Yea it is a huge pain almost tile the grooves not big enough
Old Sep 23, 2010 | 08:13 AM
Tims2006MR's Avatar
has anyone used a c-clip instead of the factory clip
Old Sep 24, 2010 | 08:16 AM
I had to use some sort of funky *** paper clip to get mine to work...
stilletto
Jun 10, 2014 05:46 AM
Metal
Dec 22, 2012 12:06 PM
jdlewh
Sep 24, 2012 02:23 PM
nytalonTSi
Mar 7, 2011 06:52 PM
jeffbum
38
Jan 31, 2010 05:38 PM
