New Exedy Twin Slipping!
Old Sep 23, 2010 | 05:49 PM
flymx771's Avatar
Just as the title says....I had an exedy twin installed and put about 1000 miles of easy street driving on it. The clutch seemed to do fine, no slipping. It was a completely different story once the car was put on the dyno. The clutch literally starts slipping at about 2700 rpms! How is this brand new exedy twin slipping without seeing any boost!?
Old Sep 23, 2010 | 06:28 PM
Brent kuz's Avatar
Where does the clutch start to grab? The usually like a high engagment, also was it properly installed...oil contamination will ruin a clutch.
Old Sep 23, 2010 | 06:40 PM
evo unknown's Avatar
How much power/torque does your car push? Who did the installation?
Old Sep 23, 2010 | 07:03 PM
flymx771's Avatar
Well we didn't get to make any pulls but I would guess it makes like 450-470whp. I doubt power has much to do with it though since it lets loose before it builds any boost. And I'm not going to name anyone unless I find out for sure they are at fault.
Old Sep 23, 2010 | 07:09 PM
o7'silvermax's Avatar
same thing happened to my triple disc but came to be the input shaft seal on the trans went bad so oil got all over it and ruined the clutch
Old Sep 23, 2010 | 07:45 PM
flymx771's Avatar
Ahhh don't tell me that, I've been through hell with this car lol. Can the input shaft seal be replaced without opening up the trans?
Old Sep 23, 2010 | 07:58 PM
EVO8STI's Avatar
damn that sucks
Old Sep 24, 2010 | 06:56 AM
92gsxbaltimore's Avatar
Originally Posted by flymx771
...Can the input shaft seal be replaced without opening up the trans?
No, sorry
Old Sep 24, 2010 | 02:27 PM
flymx771's Avatar
Looks like it was just the adjustment on the pedal. It must have not been fully engaging due to the rod not being far enough out. Does that sound about right?
Old Sep 24, 2010 | 03:31 PM
Dallas J's Avatar
Veteran: Army
If you dont have the MC adjusted right you can "pump up" the hydraulic system. That'll cause a constant load on the clutch and reduce clamping pressure.
Jacks transmissions has some videos explaining it really well and showing how to do it right.
Old Sep 24, 2010 | 03:43 PM
bbyevo8u's Avatar
is the clutch/brake line bled properly? like you said try adjusting the clutch pedal see if that helps any but i doubt it
Old Sep 24, 2010 | 04:20 PM
Originally Posted by 92gsxbaltimore
No, sorry
yes it can... you pull the trans off and pick the seal out and press in the new one carefully without pushing it in to far that is what happened to me
vtec lolz
Sep 12, 2012 09:32 PM
sliknik874
Jun 21, 2011 09:10 PM
BLKCarbonEVO
74
Apr 30, 2010 05:36 PM
str8kor
Oct 30, 2009 07:52 AM
CrackerJackToy
24
Sep 17, 2007 04:03 PM
