Milky pink transfer case fluid
Old Oct 3, 2010 | 07:47 PM
cumminsracer14's Avatar
Thats what the redline i drained out of my tc looked like depends how long it was in there.
Old Oct 3, 2010 | 08:33 PM
monkey_187's Avatar
I was told that the seals inside might be bad and the fluids were mixing. Is there anyway of telling besides taking it apart?
Old Oct 3, 2010 | 08:42 PM
evo2nv79's Avatar
If you want to get an a well educated answer get ahold of John from TRE. www.teamrip.com He's a good guy and is willing to take some time out to talk to you.
Old Oct 3, 2010 | 08:44 PM
monkey_187's Avatar
^^^^ thanks, I will get in contact with them asap.
Old Oct 4, 2010 | 06:44 AM
black95tt's Avatar
I used Redline Shockproof and mine came out just like that in both the rear diff and transfer case. I wouldn't worry about it too much. Check this thread out, it seems to be very common.
https://www.evolutionm.net/forums/ev...-come-out.html
Old Oct 4, 2010 | 06:56 AM
kikiturbo's Avatar
check your ACD fluid resevoar, if you are loosing ACD fluid..
Old Oct 4, 2010 | 07:00 AM
black95tt's Avatar
^ I could see how one would think that, but then explain why the rear diff looks the same? My ACD fluid reservoir level never changed in the last 10k miles this oil has been in.
Old Oct 4, 2010 | 08:06 AM
monkey_187's Avatar
Black95tt:
I have seen that thread before, I just want to make sure that it is common before I reinstall. Everything else is normal, fluids are coming out just as they should.
My reservoir fluid is still the same no change in color there.
Old Oct 4, 2010 | 08:58 AM
black95tt's Avatar
Originally Posted by monkey_187
Black95tt:
Sounds good. Change your fluid and be on your way!
Old Oct 7, 2010 | 09:48 AM
monkey_187's Avatar
I think this is what I will be doing.....
Old Feb 19, 2011 | 08:19 PM
rdtech's Avatar
sorry to bring this back from the dead but mine is pink when I drained and I use oem lsd fluid. It's like that the last 2 times I've changed it. I'm not sure what's causing it but I don't think it should be pink.
Old Feb 20, 2011 | 12:31 AM
xRoguex's Avatar
abused redline
Old Feb 20, 2011 | 06:18 AM
jameswwt's Avatar
Hi Guys,
sorry for off topic abit but can i use the Mitsu OEM Diaqueen LSD Gear Oil (SAE90) for my older version Mitsu Evo 5 transfer case???
Currently im using Kaaz which cost me a bomb...
rustyevo
Jul 30, 2015 04:49 PM
overdrive1
Apr 11, 2014 06:02 PM
MP Evo
33
Nov 12, 2013 10:42 PM
Evo8g23
Dec 30, 2011 12:54 PM
thedru13
12
Dec 28, 2011 05:54 AM
