just noticed how short 4B11 rods are
I have not been a fan of long rod motors. The theoretical gains are not worth the effort in my opinion. The biggest drawback to making rod longer is increased dwell time at TDC. This gives detonation more time to happen. so short rod ratios are are good thing in turbo motors.
The stock 4g63 rod length is 150mm. The 4B11 stock rod length is 143.75mm!
Don't forget the 4B11T's stroke is also shorter.
a 150mm rod in a 88mm stroke 4G63T = 1.70 rod ratio
a 143.75 rod in a 86mm stroke 4B11T = 1.67 rod ratio
So its not as big of a difference as it seems
The bore and stroke are 86mm and I think Mitsy would have tried to make the engine as light and as compact as possible . They've gone up 1mm in bore and down 3mm in stroke so together with the slightly shorter rods lost some rotating and reciprocating mass .
I think one of the shortcomings of the 4G63 is the 85mm bore and not much chance of increasing it significantly because of the close bore centers .
I think flow dynamics would be tightly controlled by the continuous VVT in 4B11T engines .
A .
A .
Just a guess...
The 4B11T's cylinder head is taller and therefore they had to make the deck height and block more compact in order to fit it under the hood? Not to mention they run the charge pipe over the head. :P maybe an idea. I've seen stuff implemented at the OEM level for faaaar less reasonable things.
I kinda agree going to a square bore for that seems a little ridiculous. Considering the bore was pretty much predetermined long before prototype X back when the block was called the world engine and it was in development with Hyundai and Chrysler. I doubt the Mitsu engineers were like "Well lets give it this bore so we can have this stroke so it fits onto this head that hasn't even been designed yet."
