Forced Performance 3794HTA now to come in Twin Scroll T4!!!!
Old Oct 16, 2010 | 11:39 PM
  #31
omniprobe's Avatar
Originally Posted by n2oiroc
Most twinscroll t4 manifolds clear a/c.
Most are usually running smaller diameter runners to clear.
Old Oct 17, 2010 | 02:28 AM
  #32
3gEclipseTurbo's Avatar
Whats the size of the vband oulet on the ts t4 housing?
Old Oct 17, 2010 | 07:58 AM
  #33
Highboost26's Avatar
yeah im ready for a 3794 kit ..
Old Oct 17, 2010 | 08:12 AM
  #34
EvoDan2004's Avatar
Originally Posted by AWD Motorsports
I never did back to back with HTA 86 but my guess is about 500rpm from what i have seen..
3 inch
Old Oct 17, 2010 | 10:37 PM
  #35
Khalid's Avatar
Its still a/c compatible with 3" it just depends on your manifold and downpipe setup..
Mike
Can you make O2 & DP to fix this unit on Shearer manifold, compatible with a/c?
Old Dec 25, 2010 | 12:39 PM
  #36
JohnBradley's Avatar
Michael has me 97% talked into this in a TS setup. I am going to a 67mm based turbo no matter what and a TS to boot, but its a matter of what one at the present. BW is looking good and as always so is the FP.
Mike,
I went looking for all the 3794 graphs you had up and it seems they are just the record ones. Any of the lower boost level you'd mind reposting? 30-40psi preferably.
Thanks
Aaron
Old Dec 25, 2010 | 12:56 PM
  #37
EvoDan2004's Avatar
Aaron what size manifold runners you going to use?
I also been thinking about making a swap from the TS HTA86 to a TS 3794. My main concern is lag difference between the 2
Old Dec 25, 2010 | 12:59 PM
  #38
1.5" with dual 38s. Going from a Single 0.82 to a 1.06 TS or something like that I doubt I am going to see a substantial difference. On yours I would suspect 500rpm or so as stated elsewhere in this thread. I'll look for a pc of the manifold...its an older design that ETS had on the shelf but they made a deal for
Old Dec 25, 2010 | 01:00 PM
  #39
Old Dec 25, 2010 | 01:05 PM
  #40
EvoDan2004's Avatar
Yea that's what im afraid of. 500 rpm for a street car Imo is alot.
If your going with a 3794 then clearly you will not be under 750 hp. But if you are the 1.25 and hta86 Imo is ideal. Which im sure u know. Lol
Old Dec 25, 2010 | 01:27 PM
  #41
Dan,
For comparison since we are both running the same turbo just different housings, where does your spool now with the TS. I know I have a 2.4, but the car is really lit off at 4400 (20+psi) with 0.82 A/r single and full boost by 5k. As a 2 liter it was basically shifted to the left 500 rpm or so at the same boost level I am running on pump, 29psi. I'll overlay those 2 graphs in my thread though rather than get this one all sidetracked
aaron
Old Dec 25, 2010 | 01:35 PM
  #42
EvoDan2004's Avatar
Dan,
aaron
Im not home right now. When I get home I will pm you my graph. I believe mine was at 31 peak psi. Spoolup on my car apparently was laggyer then now do to the avcr electronic boost controller vs the nbc I have now.
Hard to explain. But I would hit like 23/4 psi and it would then slowly creep up to 30. Now the nbc pegs 30 psi. The car I can bet makes more trq now too then its last tune. I only used to hit 20 psi in first gear. Now I reach 30.
Old Dec 25, 2010 | 01:46 PM
  #43
Gotcha. Well if you go to the last post in my build thread you can see it now. I am going to have to start a new updated one when the new kit goes on
Old Dec 26, 2010 | 01:31 PM
  #44
CO_VR4's Avatar
Dan,
Just to clarify, are you talking about internal or external diameter? Pipe or tube? 1.25" schedule pipe? 10 or 40?
Thanks.
Old May 13, 2011 | 05:40 PM
  #45
Joshs EVO's Avatar
Bump for results from anyone?
