Rough idle occurs after warm up
Old Oct 15, 2010 | 11:27 AM
jxs1984's Avatar
i had a p0401 insufficient egr flow so i went ahead and check the hoses. everything is connected so i took out the egr valve and cleaned it... the valve doesnt get stuck. i put everything back and cleared the code. the problem still exist.
the cold start is fine until 15min later the idle goes rough. engine rpm stays at 900rpm steadily but i can feel in the car go plahplahplahplahplah... feels like i have cams on it but i dont. the vacuum decreased on the boost gauge during the rough idle. i have checked the hoses, cleaned egr valve, throttle body and checked pcv valve.
my car have 72k miles on it. i have searched countless rough idle threads but they all say to check the hoses.
should i replace the egr valve?
Old Oct 16, 2010 | 06:41 PM
High_PSI's Avatar
Bump!
Old Oct 18, 2010 | 08:09 PM
jxs1984's Avatar
Originally Posted by High_PSI
Bump!
are you having the same issue?
Old Oct 20, 2010 | 08:56 PM
itsme4g63's Avatar
curious
Old Oct 20, 2010 | 09:06 PM
newimportowner's Avatar
Bump, I get this at times also.
Old Oct 20, 2010 | 10:34 PM
tscompusa2's Avatar
do a boost leak test to make sure theres no leaks.. also block the EGR with STM block off plate. screw the EGR. All that emission crap can be thrown in the garbage.
The biss screw on the tb may need turned alittle also, weather will change the characteristics of the vehicle.
fostytou
359
Oct 23, 2025 09:54 AM
Thirddead3
Lancer Troubleshooting
Jul 5, 2017 08:49 PM
soderdna
Sep 3, 2016 11:22 AM
rcheung
Jan 28, 2016 04:44 PM
ryant25bb
Sep 16, 2006 11:01 AM
