FREE Dyno test opportunity
Old Nov 30, 2003 | 11:38 AM
Alfriedesq's Avatar
I am looking for a volunteer tester with a Evo 8 for a free dyno test session to test and verify my theory that the K & N drop in pannel filter does not cuase significant changes in a/f ratios on the Evo 8
If you like the test reults you can buy a K & N panel filter at our cost - - or you can just keep your stock filter
We are looking ONLY for evos with stock air box
Old Nov 30, 2003 | 12:05 PM
BeenWaitin4Evo's Avatar
I'd do it...can you bring the dyno to me?
Old Nov 30, 2003 | 12:17 PM
b18flip's Avatar
I'm willing to take a drive up to Milford again . I' really like to see if the K&N panel filter caused my car to run lean with the xede unit, if its ok with Al and the Vishnu team. Although one question though, would my ecu have to be flashed back to stock inorder to run the xede unit and program?
Old Nov 30, 2003 | 03:02 PM
GokuSSj4's Avatar
Al went do you plan to have a dyno day on South cali ???
Old Nov 30, 2003 | 06:02 PM
turboDan's Avatar
let me know if you are still looking for a doner vehicle to run this test and when.I have a totally stock(but not for long ) with almost 1300 mileson it.Oh yea,i even live in connecticut,only abot 1hr and 15 minutes from you.let me know if you want to set something up.
Old Nov 30, 2003 | 06:15 PM
DynoFlash's Avatar
Please call me tomorrow am at 203-515-4110 and we will set you up an appointment !
Old Nov 30, 2003 | 06:17 PM
DynoFlash's Avatar
Out theory is we like to test evrything out and show real world dyno results before we start shooting off our mouths
we already have tested te K & N filter many times and it has NIL effect on the a/f curves
Its amazing how many excuses some people will make to blame others !
We are doing this so we can post up the dyno sheets and disproove the false claims that have been made
Old Nov 30, 2003 | 06:18 PM
fury656's Avatar
I'll definitely do it.
Old Nov 30, 2003 | 06:36 PM
Deceit's Avatar
Should have different people with other intake setups to show the negativity of using an intake with a MAF system
Old Nov 30, 2003 | 06:53 PM
DynoFlash's Avatar
Full intakes - eg the hks suction kit or aem intake DO throw off the maf readings - we already have tested that many times
However - what we are talking about here is a drop in panel filter which keeps the stock air box and which has minimal effects
Old Nov 30, 2003 | 07:08 PM
johnnyevo's Avatar
how funny would it be to see Al have a dyno day/session in Shivs shop! Do you think we'd ever see the day?
Old Nov 30, 2003 | 07:17 PM
turboDan's Avatar
Al,
I'll call you tommorrow and we can set something up,ok.My evo is
a virgin,for now,but have lot's to do over the winter.what's a good time to call,am,late am,noon,early pm or when.let me know????????
Old Nov 30, 2003 | 08:26 PM
Deceit's Avatar
I know Al, I'm just saying there is no real written down, documented proof, regardless of the fact that it's been tested and known of for a VERY long time.
Some people are reluctant to believe until they see hard proof. But I agree with you, the K&N drop in changes the ratio very little, not significantly at all.
Old Nov 30, 2003 | 09:16 PM
shiv@vishnu's Avatar
Hey Al,
I just got back from a weekend trip. The reason I don't recommend K&N air filters is due to oil contamination of the MAF. Happens without some people ever knowing it. This is especially a problem when folks take advantage of their "re-usable" properties and over-oil then after cleanings. Ends up inducing MAF misreadings. Same goes with foam filters which also rely on oil for filtering. The other problem with some foam filters is that they tend to harden up if not maintained and deteriorate, often getting sucked up into the turbo. This being the case, the stock airbox, IMHO, is the best choice for those who just want a good intake system that doesn't need anything more than 10K mile filter replacement.
Regards,
shiv
Old Nov 30, 2003 | 09:49 PM
chronohunter's Avatar
I can reply with a real experience with oil on the MAF. During this years One Lap of America we changed the stock filter to a K&N drop in after our dirt track round (!), as soon as I went onto the track in Memphis the car would not run right. It was real "notchy" as it reved and struggled to pull redline, it was obvious she was way down on power. We wrongly assumed it was bad gas. Turns out we had tosted our MAF, It was replaced after the event and the car was perfect again. The filter we put in was brand new out of the box with NO extra oil added (so it wasn't an overzelous re-oil). I would not have belived myself as I have always sworn by K&N
