View Poll Results: Do you smell gas in your oil?
Yes, and I broke the car in w/ the factory synthetic oil
60
55.56%
No, and I broke the car in w/ the factory synthetic oil
36
33.33%
Yes, and I broke the car in w/ mineral oil
1.85%
No, and I broke the car in w/ mineral oil
10
9.26%
Voters: 108. You may not vote on this poll
Poll: Do you smell gas in your oil?
Definetley blow by, just depends how rich you are running. The richer your car runs, the more gas that gets by the rings and into your oil. Real rich from the factory, for those like me at higher elevation it's running even more rich. Nothing that fuel tuning won't fix.
My car has this gas smell in the oil.
It was broke in on synthetic oil for 1k miles. it was broke in easy too (stayed under 1/2 throttle/4k RPM for 500 miles, then WOT but under 5k RPM for the next 500).
Also my car is running horribly rich, it puffs blacks smoke out when I hit the gas.
Motor is totally stock right now.
My car has 21 miles on it and I got it at 6 miles, Smells like fing gas. I know my VW VR 6 has no gas smell and over a 100000 on the clock I run mobile 1. This turbo break in worries me... WTF know one has any concrete info reg oil or syn.
IMO you want to run synthetic oil. There are reasons why Synthetic is put in from the factory, turbo coking aside.
Mitsubishi has to be using diamond hones these days as many manufacturers are doing. If so then they are also plateau honing the cylinders because of the finish a diamond hone produces. Plateau or brush cylinders provide a much smoother finished cylinder then 1 stage stone honing. Therefore the cylider finish should be such that the rings are not being used to clean the bores. What this means is, unless Mitsu f'd up the finish, regardless of how you break the car in you are not really doing so to seat the rings.
The convential oil arguement stems from the old method of cyliner honing and finishing where the peaks required reduction.
The prescribed breakin is more for the clutch and brakes etcthen it is for the rings.
I did smell fuel in my oil on every oil change up to the 11,250 mile one two weeks ago. as I went through the 12,000-13,000 mile range I started to feel as though the car was making a lot more power. then at around 14,000 miles earlier this week, while contemplating the performance increase, and attributing it to the recent cooler weather, I also noticed that my boost gauge was showing around 19-20 in vac at an idle. it showed around 14-16 from the time it was installed, (3,000 miles or so), until recently. I am beginning to believe that the factory synthetic oil simply delays the break-in period, (as theory would dictate it should), as opposed to "not letting the rings seat", as I have been told. the car has more power, has more vacuum, and it's oil doesn't smell like it has a quart of fuel added to it any longer.
just my two cents
just my two cents
racing_girl
Feb 9, 2013 05:57 AM
