Cam Pulley Off Timing
Old Oct 31, 2010 | 04:56 PM
Babs's Avatar
Originally Posted by still*boostn
Dude having your engine OFF timing is NOT just cosmetics,.. and you even thinking that you would be high. the ONLY way to FIX it right is to yank the timing belt and reset everything to TDC.
It takes no lie less then 45 minutes to do all of this. but sure, if your about to pay the dealership an *** load to do something as easy as a timing belt service, then maybe you ont know as much as you think.
And I DID tell you how to fix it!, "your going to have to rip it all apart and redo it. the end", what did you not get about that? that is the easy way to fix it.
Im not giving you flak. just stated the right way to do it, obivously you didnt know, so I figured id let you know, if you DID know, your timing would be right.
thnx lemme know if you want to save some money on that 60K service and learn how to do it.
You see how hard was that? Anybody can say "rip it all apart and redo it".
How would you responded to someone that wanted to know how to rebuild their motor? "Rip it apart and build it"? I'm sure they'd appreciate your input.
So now that we've finally made some progress, do I need a new water pump when I do the belts, if I decide to do them myself?
Thanks
Old Oct 31, 2010 | 05:03 PM
evoboi005's Avatar
Thanks
it be easy to do it while every is apart might as well swap it out ...then have to do it later
jhoganusaf
17
Jun 30, 2012 12:41 PM
svt_lightning01
Nov 29, 2011 01:59 AM
awdordie
Mar 10, 2011 10:14 AM
Svendiesel
14
Jan 27, 2010 07:50 PM
bbyevo8u
28
Jul 22, 2009 01:51 PM
