new motor clutch turbo weird problems help please
Old Oct 31, 2010 | 03:21 PM
mostafa911's Avatar
So i just built my head and replaced all bearings in the lower end and piston rings. I also put arp rod bolts, main studs, and head studs. I also put a act 6 puck clutch, light weight flywheel, and pressure plate. And for a turbo i purchased a fp black ported.
So i started the car for the first time everything was well drove to my tuner in the morning got it tuned all still well on my way home the car would do this sometimes in any gear i get the turbo to like 3-5 psi and let go of gas pedal i would hear a loud squeak noise like metal quickly rubbing metal and car wouldn't go into boost then if i take it out of gear rev it a bit or pull over shut the car off for a couple sec it goes into boost fine after that. The car does this non stop its annoying and also i have a check engine light for p0118 and the car will not hold idle i have to consistently rev it to keep it on. i don't know if its all related or not. The tuner didnt have any of these problems on the dyno only the idle and he said its idle air control valve. On a good note car made 450whp 401tq on a dyno dynamics.
Old Oct 31, 2010 | 04:09 PM
delcster27's Avatar
it sounds like the idling and not staying running is the iac valve to me. The metal sounds could just be the lightneded flywheel when the car studders and shuts off.
Old Oct 31, 2010 | 06:47 PM
mostafa911's Avatar
ya but it does it while im driving and then no boost how is tht flywheel
Old Oct 31, 2010 | 07:14 PM
4RETECH's Avatar
DTC P0118: Engine Coolant Temperature Circuit High Input
Check your coolant temp sensors, esp the ecu one.
Since you just did all this work I would double check that.
Good Luck
Old Nov 3, 2010 | 09:21 PM
mostafa911's Avatar
ok so what ive come up wit is i blew the turbo and spun a rod bearing gotta take it apart again danm
chaotichoax
Apr 12, 2020 11:55 PM
rgowani
30
Jun 4, 2016 01:43 PM
Spazm
May 24, 2016 09:15 PM
ezzey
May 9, 2016 09:40 AM
David Buschur
458
Aug 20, 2015 06:41 AM
