Blown turbo??
Old Oct 31, 2010 | 09:24 PM
Kapoosh1's Avatar
Blown turbo??
So coming home tonight, I decided to do a quick pull. The car spun pretty bad in first, (hit the limiter) then I hit 2nd and something popped and now I can't build any boost. I check all the obvious things like IC pipes (been there done that...a lot ). Drove around the block and it smokes a little and smells like oil.
It's to dark now to do anything, but is there anything other than the turbo I should be checking tomorrow?
Turbo's an FP red with about 22K miles on it and running about 32psi on E85. It still starts and drives no problem and sounds normal. But it won't hold idle, it'll stall out.
I was thinking either headgasket or turbo, but wouldn't it still boost if it had a bad headgasket?
Old Oct 31, 2010 | 09:33 PM
4RETECH's Avatar
If it doesn't hold an idle, I would say check all the piping after the MAF.
Also check your ISC.
If not do a boost leak test.
Good Luck
Old Oct 31, 2010 | 09:39 PM
evo unknown's Avatar
Get to the turbo and check for shaft play and then do a boost leak test.
Old Oct 31, 2010 | 09:48 PM
bigboybusa's Avatar
+1 on checking your ISC. Mine went out, Starts fine boost fine but wouldn't hold idle. Its located under your TB
Old Oct 31, 2010 | 10:05 PM
azinterrider's Avatar
Usually if its a bad turbo you will hear it start to whistle. And wont be able to build a lot of boost.
Old Oct 31, 2010 | 10:24 PM
wazmunstr's Avatar
if you blew your turbo, you should also see white smoke coming from your tailpipe.
Old Nov 1, 2010 | 01:41 AM
spider72's Avatar
try cleaning your ISC and before you install it back on, plug it in and turn the key to ON position without starting the engine the ISC should move. If it doesn't then its time for a replacement! Usually the turbo whistles when it is blown, I would get to it and check the blades for excessive play. It's also a good idea to inspect your IC pipes for oil!
Old Nov 1, 2010 | 02:19 AM
05VIII's Avatar
Were you by any chance running mobil 1 oil?
Car have a cat? Check that after a boost leak test.
Old Nov 1, 2010 | 03:17 AM
bbyevo8u's Avatar
my guess is its a vac hose that popped off, maybe the egr hose?
Old Nov 1, 2010 | 03:30 AM
MR. EVO MR's Avatar
sounds like the turbo is fine
check all hoses, all of them including under the tb, check codes too
Old Nov 1, 2010 | 03:39 AM
Kapoosh1's Avatar
Wouldn't I still be able to build boost if it was a vacuum hose??
Old Nov 1, 2010 | 06:09 AM
Kapoosh1's Avatar
There was a line hanging off by the throttle body, got that put back on. It still struggles to idle, but with the cams, big injectors and E85 it never idles that great anyways.
Still can't create any boost though. Had to come into work before I got a chance to pull the intake to check the turbo.
I checked the oil and it's a little low, kind of expected since it smells like oil and there's a bit of white smoke.
Old Nov 1, 2010 | 08:49 AM
wazmunstr's Avatar
yeah I still stand on blown turbo. pull it, and check.
Old Nov 1, 2010 | 12:02 PM
05blue8's Avatar
The turbo wouldn't cause it to not idle....that sounds like it is a bad boost leak, not one vac hose, more like a pipe.
Old Nov 1, 2010 | 12:03 PM
05blue8's Avatar
And you wouldn't be able to build boost much if any if a pipe was off, all your pressure goes out the leak before it hits your manifold where the pressure is measured at. Not to mention the air is measured at the MAF so if you have a leak after that and the MAF is seeing air but the engine isn't, it won't idle well if at all either.
