2.4 block flywheel problem
Old Nov 1, 2010 | 03:12 PM
cbuster77's Avatar
I have a 2.4 and 2.4 crank but the hole on the flywheel is to small to fit around crank.what do I have to do?
Old Nov 1, 2010 | 03:16 PM
EvoPower81's Avatar
If the crank came from an auto vehicle there is a spacer in the centre of the crank that you need to use a wrench to pull it out. Once it is a 7bolt crank it will work. I had the same issue
Old Nov 1, 2010 | 03:25 PM
cbuster77's Avatar
It was an automatic.so its just a spacer on the end That I have to somehow Yank off?
Old Nov 1, 2010 | 03:26 PM
cbuster77's Avatar
Or is this something I have to take the oil pan off to do?
Old Nov 1, 2010 | 03:31 PM
cbuster77's Avatar
Its sticking or like a half in right now at the rear main seal
Old Nov 1, 2010 | 04:10 PM
EvoPower81's Avatar
Yes looking at it at first it looks like its part of the crank but if u use a big pliers and give it a good twist it will come out.
Old Nov 1, 2010 | 04:12 PM
cbuster77's Avatar
Old Nov 1, 2010 | 04:24 PM
VTEC Killer's Avatar
Cbuster77 its called a pilot bushing, you need to remove it and then install one from a 5 speed car. If you dont install the one from a 5-speed car, the clutch alignment tool will have nowhere to slide into. You can buy a new pilot bushing from the dealer for about $6.
I remember you from somewhere either TGC or club3g? cant remember....
Either way, you dont need to remove the pan or anything like that. You if you have a good pair of vice grips or a monkey wrench, you can get it out with some patience and persuasion. Another way I have found very effective is to pack the hole in the center of the bushing with grease, insert a dowel that fits snugly into the hole (I got a wood one from home depot) then take one nice swing with a hammer into the dowel, the pressure from the grease will force the bushing out and may cause a little mess too. When you go to install the 5 speed bushing, see if it just goes in easy, if not, throw it in the freezer for 3 hours then try it, the metal will shrink a bit when cold, could help it go in.
Old Nov 1, 2010 | 05:11 PM
miragevo's Avatar
Veteran: Navy
Huuuuhhhhhh? What pilot bearing?????????
Old Nov 1, 2010 | 05:37 PM
cbuster77's Avatar
i got it,thanks for all ur help,i was freakin it,ya vtec killfer i was on club3g,bvut i was having to many traction problems and the 3g trannies are to weak so i just pickedf an evo up,im puttin my motor in from the 3g now.about the bearing i need,the 5 speed one,there is noway i can do without it?where can i get one from?
2006GSR
20
Dec 28, 2014 04:23 AM
Jsiebert
Nov 20, 2013 06:51 PM
cbuster77
Feb 13, 2011 07:27 AM
cbuster77
Jan 17, 2011 12:35 PM
NickieBlaine
24
Jun 25, 2010 11:45 AM
