knife edge build.
Old Nov 1, 2010, 07:28 PM
evo420's Avatar
knife edge build.
my build
2.0
mild knife edge crank
manly 9.5 comp pistons
eagle rods
arp main studs
map head studs
pnp head
+1mm valves springs,retainers
kelford 272 272
ets lower ic pipe
ams cast front mount
rc 1000cc
walbro
3port
4bar map
tomei arms turbo
titek o2 ported to 2.80
custom down pipe w rre cat back
act street w hd plate, light flywheel
Attached Thumbnails knife edge build.-dsc_0179.jpg   knife edge build.-dsc_0208.jpg   knife edge build.-dsc_0211.jpg   knife edge build.-dsc_0181.jpg   knife edge build.-dsc_0232.jpg
Old Nov 1, 2010, 07:47 PM
evo420's Avatar
more
Attached Thumbnails knife edge build.-dsc_0182.jpg   knife edge build.-dsc_0183.jpg   knife edge build.-dsc_0207.jpg   knife edge build.-dsc_0210.jpg
Old Nov 1, 2010, 07:54 PM
milruner's Avatar
looks good man. Where in cali are you at?
MIKE
Old Nov 1, 2010, 08:17 PM
TJSAP00's Avatar
Looks good man GL with everything!
Old Nov 1, 2010, 08:33 PM
evo420's Avatar
still working on the tune, and want to port the exhaust mani,throttle body and intake mani. this is in no way ment to be a drag car. just RR
Old Nov 7, 2010, 06:43 PM
evo420's Avatar
oh and still on 91octane
Old Feb 10, 2011, 06:48 PM
evo420's Avatar
7K miles bump still running strong!
Old Feb 10, 2011, 07:38 PM
_mcjonnyp's Avatar
whats with the dip in power at 6300?
Should put some real gas in there and really wake it up
Old Feb 11, 2011, 10:48 AM
evo420's Avatar
That graph was done on a verry rough road. With a major boost leak and tune from before the build with only minor changes. Still saving up to do all the port work and pro retune. I want to switch to SD but there is a lot of development going into new set ups so I am going to wait for that.
Old Feb 25, 2011, 10:30 AM
03upstatefire's Avatar
how much boost and what are the turbo specs? I thought i'd be seeing closer to 500 with all the engine work
Old Jun 30, 2011, 11:01 AM
evo420's Avatar
Update.
Removed intake mani, turbo mani and turbo to port out, after inspecting the turbo hotside I found cracks in the twinscrole divider. So I took it to tomei, they sent it to japan for inspection and replaced gave me a new hot side sent from japan with no question asked.
So I went out and bought a die grinder and all the bits needed and ported all peaces to match there ports or gaskets. And reinstalled with a new muse short route painted wrinkle black.
Results are the car feels more powerfule all over the place! I am now verry happy with the way it feels for being on 91octane,
Old Aug 3, 2011, 06:23 PM
evo420's Avatar
new numbers with e85 the 2 lower ones are de-tuned 91octane with only 23psi for safety at the track
Old Aug 4, 2011, 02:06 AM
azndoc's Avatar
Nice numbers
Old Aug 15, 2011, 06:24 AM
BigT's Avatar
I was hoping you could actually record a full pumpgas pull through VD. Do you have any logs where you started at say 3000rpm or lower?
Nice numbers though. Car is looking good.
Old Aug 17, 2011, 09:33 PM
BigT's Avatar
Any update to this yet? You said you would post up some more pumpgas numbers. I would really appreciate it.
Quick Reply: knife edge build.
