Possible Rear Differential Leak?
Old Nov 7, 2010 | 10:25 AM
lv05evo's Avatar
Hello,
I was changing my oil yesterday and took a look under the whole car. I noticed that the rear differential had what looked to be oil covered in dust from the top of the pumpkin. I can also see the same dust covered oil around the drain and fill holes, which I didn't clean very well I guess.
So for those who had leaks in the differential, where did they start from? I can't really see the top of the housing because of the rear sway bar and mustache bar. For now I'm going to clean everything well and keep an eye on it. Also FWIW I drive up a 1/2 mile hill at 10% grade every day. Thanks for looking.
Old Nov 7, 2010 | 10:31 AM
4RETECH's Avatar
Did you change the gaskets for the fill and drain plugs?
Old Nov 7, 2010 | 10:38 AM
lv05evo's Avatar
No, but your talking about the metal washers right? The oil covered in dust around the drain and fill holes is very slight, leading me to think I didn't clean it very well when I was servicing it last. The oil from the top of the rear diff housing is covering about half of it.
Old Nov 7, 2010 | 10:40 AM
barneyb's Avatar
What was the level of the fluid you drained?
Old Nov 7, 2010 | 10:54 AM
lv05evo's Avatar
I didn't check the level before I drained it. I do make sure the car is level with a level and add the recommended amount. I never add too much fluid and it never overflows when filling. I use Mitsu Diaqueen.
Old Nov 7, 2010 | 05:39 PM
4RETECH's Avatar
I had them leak because I reused the drain washer.
The rear diff looks like oil is all over the place, due to the turbulant air in the back. I used brake kleen to wash it down after changing it to a new washer and no more leak.
The key is to save the new fluid you just put in to reuse it. A very clean pan and suction gun work well.
Old Nov 7, 2010 | 07:32 PM
lv05evo's Avatar
Ohh you took off the whole cover to service it. I think this is how I'm going to do it this time around because of the leak somewhere near the top of the pumpkin.
Do you use a new factory gasket for the cover?
Old Nov 7, 2010 | 09:59 PM
TommiM's Avatar
the rear differential uses rtv not a gasket to seal the rear cover if thats what you were asking
Old Nov 7, 2010 | 10:50 PM
lv05evo's Avatar
Yeah that's what I was asking. I haven't looked in the repair manual yet. Just seeing if I could get pointers.
asu11
Jul 26, 2021 04:24 PM
javievo9
Jun 18, 2017 06:23 AM
deylag
Evo X How Tos / Installations
Sep 28, 2016 08:13 PM
HatrixMouse
14
Sep 27, 2016 09:42 AM
19DB794
Aug 3, 2013 07:25 PM
