Evo 8 rear differential ilquefying oil
Subscribe
Jun 15, 2017 | 02:31 AM
Hi i was wondering if someone know where find to purchase for the rear differential the seal or gasket or whatever they use to seal them . The liquefying oil is from the front of the rear differential, any help it wuold be apreciate
Thanks
Reply 0
Jun 15, 2017 | 08:53 AM
Amazon Amazon
Front pinion seal, part # MB393929. Might double check me, but this should be it.
Reply 0
Jun 15, 2017 | 09:07 AM
Yeah, needs a pinion seal. Get a new pinion nut as well, it's not recommended to reuse them. Make sure you torque it to spec on assembly.
Reply 0
Jun 15, 2017 | 01:03 PM
thanks
Reply 0
Jun 17, 2017 | 03:37 PM
Hi wath oil i can use ? some mechanic tell to me that make a mix with the sane oil that have inside the rear differential with Shaffers 75w-90 supreme gear lube , that is rigth or no ?, let me know wather you knows
Thanks
Reply 0
Jun 17, 2017 | 10:02 PM
OEM works. Never heard of Shaffers.
Reply 0
Jun 18, 2017 | 04:16 AM
You said that Genuine OEM Mitsubishi SAE 90 Transfer Case and Rear Diff Fluid (Diaqueen)
Reply 0
Jun 18, 2017 | 06:23 AM
Quote: You said that Genuine OEM Mitsubishi SAE 90 Transfer Case and Rear Diff Fluid (Diaqueen)
Yes that one, idk about pr but in us evos we have to fix and reinstall the clutch plates correctly... might as well lol.
Reply 0
Subscribe
