Billet Output Shaft???
Old Nov 10, 2010 | 05:34 AM
Donkeypuncher's Avatar
Awesome, thanks for the info. I was quick slipping the clutch and never really dumped it, but I didnt really "load" it either. I think I was holding the clutch too far down, I should have probably held it in closer to engagement. Thanks for all the great info! I figured I should learn this before breaking another 5k in parts.
Originally Posted by sho669
Slowly letting the clutch out untill you can feel it start to drag, this "loads" the drivetrain. You can also use the e-brake method but I haven't tried that one yet. From that point you can quick slip the clutch and its a lot easier on the drivetrain. You're lessening the inital shock off of the gears by taking the slack out of the drivetrain before putting the power to it.
I'm guessing you were doing straight clutch dumps, I did the same thing when I got my car. Four runs (300whp) and BOOM, off to Shep for a trans build w/output shaft and a stage 3 t-case with a new ring/pinion. I read up and learned how to launch the car after that.
Theres a ton of threads in the driving techniques section about launching.
Yota Eater
Jul 20, 2016 10:24 PM
stunna2o1
12
Jan 19, 2016 11:44 PM
blowngasket
Apr 13, 2013 10:40 AM
APM Racing
Midwest Region
22
Jun 1, 2011 02:33 PM
Nastynine
Apr 10, 2010 05:45 AM
