winter Project ''project 9'' by Evodan2004.
Old May 18, 2011 | 01:22 PM
  #211
bolio's Avatar
good luck getting the 9's Dan, did you use E85 and turn the boost up?
Old May 18, 2011 | 01:25 PM
  #212
EvoDan2004's Avatar
no not yet. right now its on 100oct. i do not have E85 local to me. i will be doing a E85 tune but i want to run 9s on a local fuel and street tires.
Old May 18, 2011 | 01:29 PM
  #213
06MREvo's Avatar
Originally Posted by evodan2004
thanks man. yea ill be going to island drag way. right now i am pacing back and forth at the garage door to get the car out. its been raining here since saturday night when i got home. weather chan says rain till friday
Yeah man, this weather is ridiculous...I just checked Island's schedule...They have test and tune this Sunday if your interested...Next Friday's the track is closed...Let me know when you are going man, I need to PM you my # again...
Old May 18, 2011 | 01:44 PM
  #214
EvoDan2004's Avatar
right now sun looks to be the day for me. not to sure yet. but i think ill be going in the morning
Old May 18, 2011 | 01:50 PM
  #215
06MREvo's Avatar
Gates open at 11am...track @ noon...
Old May 18, 2011 | 01:55 PM
  #216
EvoDan2004's Avatar
crap. there go's the AM. ok well i guess it will have to be at noon then. HAHA. pm me sat night and ill let you know if i am def able to go.
Old May 19, 2011 | 07:16 PM
  #217
EvoDan2004's Avatar
got some bad news. well its not bad. but for the time frame its bad. ill explain as best as i can.
the car on the dyno was tuned with 100oct 40psi with a BR double pumper and 1200cc injectors. on the dyno with the FF intake we saw 90% duty on the injectors. sean knew the FF intake would make a difference on the street so after around 100mph he has the FCON set to add 2% more fuel.
anyways i took the car out on the road today to make sure all is well for sundays track day. 1st 2nd and 3rd gear are retarded. but once i hit top of 3rd and shift into 4th the car begins to get very lean. on the dyno it was in the 11.6/8 afr range. 4th gear up to 7000 rpm ''cause thats where i got out of it'' i am showing 12.5 AFR. so i spoke to sean and he thinks the FF intake is causing it to go even leaner. which makes sense because the force of air on the road is much greater then on the dyno. he said to lower the boost a few psi and see what happens. it gets better with less boost and at about 35psi it runs strong. but this wont cut it for are 9 second goal.
so in the mean time i pulled the pumps out and pushed the reliefs down to get more out of the pumps. i am hoping this will help. ill find out tomorrow when i take the car out. what do you guys think???
if that does not help then ill be running sunday with 35psi. which is ok with me because i want to get a good feel for the car, clutch and launch. i just dont think ill be ripping a 9 second pass. if i can i will be getting the ID2000 injectors this week and if sean has time a retune with them in. i think this time we need a highway and not a dyno. HAHA.
Old May 20, 2011 | 08:28 AM
  #218
06MREvo's Avatar
Beast...Shes thirsty!! I think your right Dan, sounds like 3rd & 4th gear pulls need to be done on the highway after the dyno...Hopefully the weather holds up for Sunday!
Old May 20, 2011 | 08:31 AM
  #219
EvoDan2004's Avatar
im going to test out the modded pumps in a few hours. if it does not help then ill be limited at the track.
i just called STM to place an order on a FPR kit and fuel line's. i got to call back in a half hour to talk to Emery.
i am trying to find info on the aeromotive 340 intank pumps as i want to buy 2 fuel pumps that flow more then the walbro 255's.
also i need to order ID2000 injectors. i think after this is all fixed up i will not need anything ever again. i hope not
Old May 20, 2011 | 08:38 AM
  #220
06MREvo's Avatar
Ballin!!! That will be a nice fuel setup...Keep us updated man!!
Old May 20, 2011 | 05:23 PM
  #221
tscompusa2's Avatar
i bet it fixes it. modding the pumps makes a huge difference.
Old May 21, 2011 | 11:29 AM
  #222
EvoDan2004's Avatar
i hope so. i hope i dont need a retune because of it too.
its raining again here so i hope i can get it tested later today.
Old May 21, 2011 | 11:31 AM
  #223
06MREvo's Avatar
Raining?? Its hot and sunny in Clinton...
Old May 21, 2011 | 11:35 AM
  #224
EvoDan2004's Avatar
i have not seen the sun since last sunday. its rained every day this week and i worked last night from 9pm to 9am and it was really nice out. i woke up at 1pm and went to pull the car out and its poring rain. wtf
Old May 21, 2011 | 02:15 PM
  #225
EvoDan2004's Avatar
Ok I took the car for a ride. There is a definite difference but I can't really tell if its 100% cause the roads are wet and the tires keep blowing apart at 80 mph in 4th gear. But its deff improved
