winter Project ''project 9'' by Evodan2004.
UPDATE.
new coilovers are here. just waiting on the springs. i also bought a 400lb .01 accuracy didgial scale.
guess i got something on my mind.
on a side note. i bought a rear sub frame from a member the wed before Xmas. ''Dec 22, 2010'' and never received it. so i have a pp dispute im going threw with that. . in the mean time i bought another one from another member which i also have not received yet.
i got all the nuts,bolts, washers, suspension hardware from mitsubishiparts.net. thanks Russel M.
ok well thats it for now.
guess i got something on my mind. on a side note. i bought a rear sub frame from a member the wed before Xmas. ''Dec 22, 2010'' and never received it. so i have a pp dispute im going threw with that. . in the mean time i bought another one from another member which i also have not received yet.
my new digital scale arrived today. o man im a happy boy. HAHA. im weighing everything.
besides that. the rear sub frame weighs 22.2 lbs. let me see how much lighter i can get it. i would like to get 2.2 lbs off it. maybe more. the grinding begins.
Nice...pics once the grinding is done! You get my PM?
I keep seeing more and more talk about light weight rear sway bar...and you and 03, have me thinking about pulling my heavier then stock (2-3lbs) 27mm Progress sway bar off the car and get something lighter. I've had the Progress on there for 4 yrs now and enjoyed the handling improvement I got over the stock rear one. The Progress bar is solid and obviously stiffer then stock. My car is not just a straight line car, Autox & road course as well. The Hotchkis bar is hollow, only 24mm but probably 6-7lbs lighter then my Progress bar. From what I can find the Hotchkis is 2mm larger then stock and I'm sure slightly stiffer. The weight difference would be worth it but I am hoping I wouldn't loose any handling performance going to a sway bar that is 3mm smaller and not as stiff. So what do you think Dan, do you think I would loose some handling performance and be able to feel the handling difference between the 2 bars??
Thanks. There a bit heavyer then expected but whatever. Gonna pull out the megans and weigh them this week.
On a side note I think im going to have a aluminum dp back exhaust made. I already have a custom br 3.5 dp back with TI muffler that is light as hell for a 3.5 exhaust but if I can get more off then why not. Got to do some reading on that some first. But im pretty sure I want it.
haha, alright ill post it in his thread...at this point I am not going to bother with the front sway...I may do it when I do my 5 spd swap...
Sorry Collin couldn't help you out with that exhaust, you having a local guy do it? PM me the answer if you don't want to post it on here...
i pulled the rear megan coilovers out of the car and weighed them. there 9.0lbs. the N1 coilovers are 8.2 lbs. ill pull the fronts out later and see what they weigh. i dont expect much difference because looking at the 2 rear coilovers togeather they look exactly the same. the only difference is the spring. one is longer then the other. and IMO thats the .8 lb difference. lets see what the fronts weigh in at.
