WG flutter...(video)
Old Dec 16, 2010 | 03:57 PM
  #46
05VIII's Avatar
Originally Posted by meat_EVO
every grimmspeed EBCS i have ever seen tuned (3) have had the wastegate flutter.
One thing newcommer did, he used the smallest vaccum lines possible and he sai dthat gave him the most consistant boost control with the grimmspeed ebcs.
but did it get rid of the flutter? mine holds 30psi strong and consistent, its just the flutter i dont like.
just got off the phone with fullrace and they are finishing up my dump pipe and sending it off monday so ill be able to try all the suggestions end of next week hopefully.
Old Feb 2, 2011 | 03:41 PM
  #47
Eisen7's Avatar
Bump for this issue. Mine is nowhere near as bad as the video's posted by the OP, but there's definintely a flutter occurring as the turbo builds up to peak boost (26psi) between 3500-4000rpm. I thought it was comp surge...
I'm running an FP Green (non HTA) with 18psi WG actuator and all the usual supporting mods.
I just changed over from an Apexi AVCR to the Grimmspeed for ECU based boost control. No other changes and now I get this flutter sound, whereas on the AVCR it never occurred
Does everyone have port 1 on the Grimmspeed routing back to the intake pipe? See attached. Someone mentioned that it's more 'optimal' to remove the hose which hooks up to the intake?
Will try and post up a video soon too.
Old Feb 4, 2011 | 11:35 PM
  #48
Eisen7's Avatar
Just to confirm, removing the line from port 1 on the Grimmspeed to the intake pipe didn't fix the flutter. I just tried it then
Seems that the Grimmspeed just doesn't like too much WGDC. If it's backed off, then it doesn't flutter, if you bring it back up to hit target boost, it flutters again...
Old May 16, 2011 | 01:08 AM
  #49
ob5's Avatar
ob5
Bump ive got this issue still with my 3 port (same style as the grimmspeed)
Old Oct 29, 2011 | 11:17 PM
  #50
nocabiwiksmx's Avatar
bump, i have this issue with a tactrix 3 port
Old Oct 30, 2011 | 01:44 AM
  #51
05VIII's Avatar
holy ****.. i didnt know this thread was still going.
well supposedly the fix for this is in the tuning. you can tune the BCS a certain way to get rid of the flutter. I havent gone in for a tune in a while so i havent gotten it checked out. as soon as i get a tune and get the flutter resolved ill post up here with how my tuner did it.
Old Nov 1, 2011 | 12:12 AM
  #52
Slowvac's Avatar
I have the same issue when using the 8MR turbo with the Grimmspeed 3port (at 1.3bar using a 1.3bar wastegate). Sounds like I'm not the only one having the same issue.
Old Nov 1, 2011 | 11:40 AM
  #53
mexfizzle's Avatar
i also have the same prob with my grimspeed 3 port mine sounds like **** do check it out its only a friend next to me .. mind him
http://www.youtube.com/watch?v=2Bzl8...eature=related
Old Nov 2, 2011 | 07:56 AM
  #54
JScocchio's Avatar
Just switched to the Grimmspeed 3-port (from an MBC)... and now I am getting this too!
It doesn't appear to be effecting performance as far as I can tell... is anyone actually having performance issues or is everyone just pissed because of the annoying noise it makes?
Old Nov 2, 2011 | 08:38 AM
  #55
Locdizzel's Avatar
my tuner told me it totally normal with the 3 ports, im running a gm 3 port and mine does the same
Old Nov 6, 2011 | 06:33 PM
  #56
its more the scary compresser surge-esque sound
its defo wastegate like you say, i did some tests and i doubt my car surges at 1 bar lol
fixing it would be good but its not a high priority for me at the moment
Old Jan 6, 2012 | 10:24 AM
  #57
Evo8RLK's Avatar
05VIII- I have this same issue with the grimmspeed.. aem truboost never had this problem at the same boost. Did your tuner fix the problem?
Old Jan 13, 2012 | 11:51 AM
  #58
Revobasher's Avatar
Same issue here I think.. but I added the Grimmspeed (also running Hallman MBC), Turbosmart Race Port and also went SD at the same time.. So I am nto sure which is the culprit. Video:
http://www.youtube.com/watch?v=pePwP...1&feature=plcp
Old Jan 14, 2012 | 06:51 PM
  #59
Locdizzel's Avatar
^ That sounds more like compressor surge/ BOV surge, but i could be wrong, but i get WG flutter when i hit peek boost and BOV surge if i release throttle at mid to high boot levels with my synapse. ill try making a vid tomorrow
Old Apr 9, 2013 | 05:33 PM
  #60
turbo speedy's Avatar
did any one ever find out the cure for this? My car makes the same sound over 36psi but under 36 no flutter... its absolutely driving me crazy.
