Change Rear Axle Boot
Old Nov 21, 2010 | 11:23 AM
Sacevo9mr's Avatar
My driver-side Rear axle boot cracked and is leaking all over the inside lip of my rim, Instead of buying the whole axle replacement i bought a direct replacement boot with grease pack from the dealer.
I plan to take it all apart tonight when i get home, I was looking for a direct write up but can't seem to find one in the how to's or on any other website. Is there anything i should look for? Or does anyone know the exact steps to take so i don't waste time removing things i don't need to.
Thanks
Old Nov 22, 2010 | 09:58 AM
xexitenglishx's Avatar
I had mine done by turbo trix... They told me you pretty much have to pull the whole axle out off the car. Then disassemble it just to get the damn boot on then reassemble everything.
I was going to do it myself but never got time and just got it done while i had my clutch done. When i searched for info on it most people didnt have a write up or they just said they were just going to leave it ripped... I assume its pretty straight forward once you get the axle out of the diff...
Old Nov 22, 2010 | 10:24 AM
Sacevo9mr's Avatar
Alright ive also been told to just to disassemble the lower control arm and nut off axle and should have enough give to swap it out.
Old Nov 22, 2010 | 10:38 AM
might be possible. Thats how i was going to do it first but they told me otherwise...maybes its jsut easier with the axle off? i dont know but good luck...maybe take some pics and do a small write up to benefit everyone else!
Old Nov 22, 2010 | 11:10 AM
barneyb's Avatar
The inner boot has to come off before the outer boot can be installed. You disassemble the tripod, remove inner boot, remove outer boot. Assembly is the reverse.
EVIL_EV0
10
Aug 17, 2017 10:15 AM
Jovan Caro
May 25, 2017 09:24 AM
97laxlude
Feb 28, 2017 07:11 AM
Johnr352
11
Oct 15, 2014 07:59 AM
Sacevo9mr
Feb 3, 2011 06:39 AM
