late spool on a 50 trim (help)
From: Poughkeepsie NY, Central Jersey Shore, Fort Meade MD
looked through other threads but didnt really see anything on my issue. im in the process of building a beast but still new to the 4g63 from the honda game. my evo currently has a agp 50 trim on it which starts spooling around 3700 and doesnt hit full boost of 23psi till around 4300. any ideas as to what may be the issue? i have been told thats real late for a 50 trim.
my currant mods are:
hks 272's
large fmic
turbotrix upper and lower icp
turbotrix gt turbo kit w/ tubular manifold
agp 50 trim turbo
forge blowoff and wastegate
3" tbe
880cc injectors
walbro 255 pump
3" intake w/ k&n
tuned on stock ecu @ 23psi
anyone have any ideas what i should look at??
hks 272's
large fmic
agp 50 trim turbo
3" tbe
880cc injectors
walbro 255 pump
3" intake w/ k&n
Here check this thread out. This should answer your question.
https://www.evolutionm.net/forums/ev...im-debate.html
hks 272's
large fmic
agp 50 trim turbo
3" tbe
880cc injectors
walbro 255 pump
3" intake w/ k&n
hks 272's
large fmic
agp 50 trim turbo
3" tbe
880cc injectors
walbro 255 pump
3" intake w/ k&n
well im back in iraq right now so not really sure what the afr is at spool but its running on 93oct on a tune by i think turbotrix....car had the currant mods when i bought it. just trying to see if i cant find the reason for late boost till i get my beast build finished
make a boost leak tester: read this for quick reference: http://www.vfaq.com/mods/ICtester.html
basically putting pressure through the engine via the turbo inlet and listening for leaks and watching boost gauge.. soap and water in a spray bottle also assists in finding leaks via bubbles.
Question tscomp...what does temperature have to do with spool? I have always heard that a turbocharged car loves cold weather but does it affect performance that much? I notice my car sputtering from time-to-time and revs bouncing back and forth occasionally. I was also tuned in the summer time.
well if thats the case and its not a boost leak then i will just wait because i plan on doing a aem ems for my build im doing and looking at 2.4 longrod set up so not to worried about the spool times for the larger turbo since im only doing the .63ar with it
Stock ecu is the most powerful ECU you'll ever find for your Evo. Its your money though.
You can have multiple tunes with map switching on the stock ecu. Buschur racing sells a quick map switching kit. Check it out: https://secure.buschurracing.com/cat...76f1c073e76aee
