Problem with boost. 25 psi donw to 18 psi...
The larger displacement engines seem to have a problem with taper through the 10.5cm housing. Either try radically hogging out the stock 10.5 housing, going to a larger A/R Australian housing, or putting out the cash for the prototype dual-gated TS tubular stock manifold from ETS.
fp black. id like to try and hold around 37 uptop is this possible. Its on a fully built motor, 2.3L stroker with a race head. when i ran it at wastegate pressure (25psi) i would get a creep to 29psi uptop, id like to run it at 35psi and have it actually hold 35psi until redline, or is this to much to ask out of a stock frame turbo? When I run it to 40psi it will hold the 34-35psi im asking for.
I reread your initial post Mauri and I believe that the boost taper you are experiencing is normal for the IX 16G turbo configuration. I think that the taper can be remedied or significantly reduced by porting the turbine housing.
Also, I have an FP Green turbo sitting around here that doesn't taper or creep with a fully ported turbine housing. We could swap this Green for your IX. Let me know. Or else bring or send me your turbine housing on TICA Bus and I'll port it for you.
Shoot me a PM.
Shoot me a PM.
So, Mauri, I am still wondering where exactly your external gate is sourced from. Is it flanged onto the exhaust manifold, or is it sourced off the turbine housing, the O2 housing, etc.?
