Difference in the fp red
what are some differences between the 3 types of Fp reds, in regards to spool, power, and etc.
The three different ones im seeing are the Rebuilt stock turbo to an fp red, 64mm red, and 80mm
they are all the same the only difference is the fp red with the 84mm surge cover helps prevent it from surging. the original fp red 64mm housing surges so they made that cover to help reduce it. If you send in a turbo to get transferred into a red you either add the surge cover or you dont effectively making it into one of the two types i just listed
NO they use new cores for the new turbos used cores are sent in by the user and converted. There is no difference if you send in your turbo EXCEPT WAIT TIMES and deciding surge cover or not. I hope you get the surge cover option would be crazy not to and have your hotside ported
The only other thing I've seen is that the smaller cover use to put out a little more hp, but not sure if that's still the case. I also remember that folks mentioned a slight loss in torque when switching from the smaller 64mm stock sized cover to the larger cover. I would have gone for the larger cover and oil line kit if they were around when I bought the turbo had it been available back then, but oh well, I still love my FP Red
NO they use new cores for the new turbos used cores are sent in by the user and converted. There is no differenced if you send in your turbo EXCEPT WAIT TIMES and deciding surge cover or not. I hope you get the surge cover option would be crazy not to and have your hotside ported
2nd that, just get a new one with the 84mm cover and be done. The 64mm and 84mm numbers do not refer to the size of the compressor or turbine wheel inside, its simply the diameter of the inlet where your intake attaches to. I feel like thats something that confuses a lot of people is seeing those numbers and assuming it has to do with the size of the wheel(s) inside.
before my fp black i had the orginal 64mm fpRed without the new surge cover and never had any problems with surge....i love that lil turbo and still have it but now i love my black.....fp has great turbos wont ever buy from anyone else
