Billet 6765 surging ?!?!
Old Dec 2, 2010 | 02:14 PM
rh9's Avatar
rh9
Angry Billet 6765 surging ?!?!
I have tuned my evo to 1.6 bar so far, anything over 1.7-1.8 bar and the turbo surges badly all the way to redline in every gear
I'm using the ported compressor housing and use an apexi avc-r to control boost On a 3" intercooler and 2.5" piping
My head isn't ported but with tomei 280 cams
As soon as the car boosts over 1.7 bar it starts compressor surging all the way
what's up with that ?
Old Dec 2, 2010 | 02:16 PM
rh9's Avatar
rh9
I'm also running the t3 0.81 ar on a full race manifold ...
Old Dec 2, 2010 | 05:54 PM
ScorpionT's Avatar
Can you get a video for us? That would help.
What manifold are you running? External wastegate dump or is it plumbed into the downpipe?
Old Dec 2, 2010 | 05:58 PM
_mcjonnyp's Avatar
make sure your bov isnt leaking, and has a proper spring
Old Dec 2, 2010 | 09:18 PM
BenJ's Avatar
What BOV are you running?
Old Dec 3, 2010 | 12:06 AM
VRSF Tiago's Avatar
Why are you only running a 3" intercooler on a 6765?
Old Dec 3, 2010 | 12:13 AM
AWD Motorsports's Avatar
Something wrong in the setup not turbo.. we ran 40+psi no surging issues..
Mike
Old Dec 3, 2010 | 05:58 AM
TiALSport's Avatar
a leaking bov can actually help prevent surge...
Old Dec 3, 2010 | 06:33 AM
GreenAWD's Avatar
Possibly the boost controller...
Old Dec 3, 2010 | 07:09 AM
Kasey's Avatar
This is what Im betting on. You probably have to much or not enough duty cycle in the settings of the boost controller.
Old Dec 3, 2010 | 10:13 AM
KevinD's Avatar
what do you mean by surge?
have you considered spark plug misfire, or possibly a boost leak due to a coupler stretching at higher boost levels?
Old Dec 3, 2010 | 10:57 AM
JohnBradley's Avatar
Gain setting is probably wrong and you are getting WG flutter, not surge. I havent seen large turbos surge even under some pretty insane attempts to make them do it. If you arent already set the AVC-R to run just WGDC and nothing else and see if it goes away.
Old Dec 3, 2010 | 12:28 PM
Xenogenic's Avatar
I'm going to blame it on the boost controller. Try a hallman and what bov are you using. Also what is it doing specificly. A lot of people define surging wrong. Do you mean its boost surging like the psi jumping?
Old Dec 4, 2010 | 03:23 PM
rh9's Avatar
rh9
I'm running a full race manifold and an HKS ssqv bov which I'll remove in few, I hate bovs to be honest
I'm also upgrading the 3" Intercooler to 4" ETS very soon
After playing with the apexi avc-r's setting it seems to have gone abit better.. I'll install the external bosch 044 fuel pump in few days and boost up, I'll let you know
Old Dec 4, 2010 | 08:35 PM
deebo3726's Avatar
how so?
Appauldd
44
Oct 25, 2010 10:33 PM
ItalianEvo
Nov 14, 2009 09:34 AM
l2r99gst
Sep 17, 2009 07:12 AM
ItalianEvo
Dec 20, 2007 12:53 AM
ItalianEvo
Jun 13, 2006 12:52 PM
