Fuel Line fitting question
Old Dec 6, 2010 | 01:11 PM
awdboosted's Avatar
Does anyone know what Earls fitting or any other brand fitting that would fit on the stock fuel line and adapt it to a -6an??
So the stock fuel feed line to the fuel rail. The one that connects from the hard line into the rubber hose.
Old Dec 6, 2010 | 01:14 PM
Fast_Freddie's Avatar
Veteran: Navy
Well you have AMS fuel line, but I am sure you are trying to build it yourself and I am also curious...
Old Dec 6, 2010 | 02:08 PM
awdboosted's Avatar
Yes I am try to build one myself. I have this fitting Earl fitting
It threads in but I'm worred that it's not set up for a double tube flare.
Old Jan 12, 2011 | 04:55 PM
Wheatley's Avatar
I was just looking for the same thing.
Old Jan 12, 2011 | 05:03 PM
Teh_Evo's Avatar
Let me see what I can come up with...
I know a fellow evo owner that did exactly what you are talking about. He said they make a fitting that clamps on to the stock hardline without having to do much modification.
**Edit, like this?
http://www.jegs.com/webapp/wcs/store...pter+Fittings+
Old Jan 12, 2011 | 05:16 PM
Wheatley's Avatar
Ive seen that and I dont mind cutting and flaring it to just use a reg hose end but I was looking for an actually thread fitting. the only thing I can find is a 14mm reverse flare to -6 but I dont know if that is correct. I might just cut the fitting off and flare it and use it as my return and just put a -8 in as my feed.
Old Jan 14, 2011 | 10:14 AM
awdboosted's Avatar
That sounds like the only solid solution. Please post results if you do this before me and I'll do the same. I just will not have any way of pressure testing this untill I put my car back together.
Old Jan 14, 2011 | 10:24 AM
Wheatley's Avatar
With it being the return it only needs a little flare to hold a hose on to prevent it from slipping off. It doesn't have hardly any pressure. Im doing the same to my PS line to reroute them. I doubt I end up doing anything with the fuel line the stock lines are good to almost 800hp on ethanol.
Old Jan 14, 2011 | 11:31 AM
awdboosted's Avatar
I'm talking about the feed line. The return line isn't an issue for me.
Old Mar 12, 2011 | 01:28 PM
C3L1CA's Avatar
Does anybody know if these are the same fittings?
http://www.034motorsport.com/hardwar...ing-p-391.html
http://www.jegs.com/i/Earls/361/9894DBH/10002/-1
The 034 motorsports says it is the inverted flare fitting but the Earl's does not.
Old Mar 13, 2011 | 09:44 AM
awdboosted's Avatar
I know we need a inverted Flare to make this work. I own the Jegs one and it's not inverted.
Old Mar 15, 2011 | 01:48 PM
awdboosted's Avatar
I email the vendor. It's the same fitting.
Old Oct 17, 2011 | 05:00 PM
LCS's Avatar
LCS
How thatīs supposed to seal? It comes with no oring.
Old Nov 11, 2011 | 01:51 PM
LCS's Avatar
LCS
Found out the Earls fitting wonīt seal. But this one works:
http://tunersnation.com/ZenCart/inde...oducts_id=1742
For my car I decided to run a -6AN line from the pump to the rail.
Old Nov 12, 2011 | 06:45 AM
awdboosted's Avatar
Did you actual buy it and get it to work??
I know the fitting is 14mm X 1.5 and this one looks to be 7mm
Any thoughts?
