Fuel Line fitting question
Old Nov 14, 2011 | 03:21 AM
LCS's Avatar
LCS
Originally Posted by awdboosted
Did you actual buy it and get it to work??
I know the fitting is 14mm X 1.5 and this one looks to be 7mm
Any thoughts?
It´s 14mmx1,5. The 7M written there is the Supra model.
I didn´t buy that fitting because I live in Brazil and was in a hurry to start the engine. So I decided to run a hose from pump to rail. But I researched a lot and found a thread on a DSM forum regarding the Earls fitting and it´s inability to seal against the oem pipe.
Old Nov 18, 2011 | 02:51 PM
awdboosted's Avatar
Well thanks for finding that.
Old Dec 10, 2012 | 09:23 PM
Evo_AK's Avatar
Veteran: Air Force
Sorry to bump an old thread, but did anyone get this to work? Wanting to make an AN line for my feed, but need the conversion piece.
Old Dec 10, 2012 | 10:16 PM
jessmanEVO's Avatar
I finally found it!!!!!!
http://www.jegs.com/p/Russell/Russel...29877/10002/-1
Exactly what I used on the stock hard line under the hood.
Old Dec 10, 2012 | 10:23 PM
Evo_AK's Avatar
Veteran: Air Force
Which fitting did you use? And does it just screw onto the hard line fitting?
Old Dec 10, 2012 | 10:26 PM
jessmanEVO's Avatar
Iirc it was this one http://www.jegs.com/i/Russell/799/64...ductId=1329877
The 3/8 to -6
The small part with the slit actually has threads on it that the picture doesn't show. You would put the hard line through that slit, then screw the cap with the -6 onto it.
Old Dec 10, 2012 | 11:54 PM
Evo_AK's Avatar
Veteran: Air Force
So the fitting with the slit goes underneath the hard line fitting and pushes it up into the AN piece? Sorry if that sounds confusing.
Old Dec 11, 2012 | 01:21 AM
jessmanEVO's Avatar
It actually screws in
DSMolition
Aug 20, 2016 03:35 AM
asu11
May 10, 2016 09:37 PM
CO_VR4
10
Mar 17, 2014 01:18 PM
evoballer
Feb 15, 2012 06:49 AM
M8NSTER
Evo X How Tos / Installations
Jun 16, 2009 11:23 AM
