Neutral Clutch Engage=Creep Forward
Hey all -
When I engage the clutch (release the pedal) after first starting the car and it's in neutral, the car "presses forward". You can feel it TRY to move. Revs bog a hundred RPM or so, an the car wont move, but you can feel it try.
It happened today for the first time after sitting in the ~20 weather while I was at work for 10 hours.
There's also a rattle that goes away when I depress the pedal. Been like that since I bought the car with 48,000 miles, now has 51,000.
Any ideas of if my clutch is dying or tranny/t-fer case fluid may be too thick for the cold weather? After it warmed up all seems well.
Thanks for feedback!
happened to me when my clutch pedal needed adjusted...does it seem like clutch pedl is pretty high up when it is engaging? I adjusted mine and it went away for about a year....
I'm guessing your fluid is thickening up because its cold, mine will do that too, but once the fluid is warm, it doesnt. The rattling is just your Throw Out Bearing, they tend to make noise a lot in Evo's
Yeah, fluid coupling in the transmission. In neutral, I was able to drive my old DSM around the parking lot one bitterly cold morning after working all night. Once I realized the car would move I decided to see how far it would go.
This was with Mobil 1 gear oil in the tranny, the first synthetic gear oil. Maybe synthetic but the stuff got stiff in the cold.
Did that with my '03 Nissan Sentra SER Spec V, '04 Dodge SRT-4 and '06 Mitsubishi Evolution 9 .
Its because the temperatures are cold out and the cold oil drags in the transmission.... Something along those lines...
Ok,,I have been told this a few times now and realize it's what's going on and normalish. Fynny thing is I've owned 21 cars, most manual transmissions, and never experienced this.
The only time my 1G DSM offered to do this was when I had Mobil 1 in the gearbox. BTW, Mobil 1 was no friend to shifting in the cold either. This was maybe 15 years ago. So, whether you have encountered this or not may depend on the gear oil used.
bbong
Jun 11, 2017 05:25 AM
silverevo05
13
Nov 5, 2007 07:07 PM
KazzEvo8
Dec 30, 2004 10:40 AM
