New ATP Ball Bearing Setup
Old Jan 18, 2011 | 02:48 PM
  #181
4g63evoeight's Avatar
i'd like to see results from this awell.. like mikey said i have a feeling FP has some DBB in the works.. just a gut feeling. but its ethier this or a Black. probably a black.
Old Jan 18, 2011 | 03:51 PM
  #182
06MREvo's Avatar
Like I said I'm sure both FP & CBRD on in the middle of developing DBB stock frame turbos but it will probably be a year or so till they come out...sucks...
Old Jan 24, 2011 | 10:51 PM
  #183
06MREvo's Avatar
TTT....Any shop pick one up for testing or anybody pick one up for their person car yet???
Old Jan 24, 2011 | 11:43 PM
  #184
BLKCarbonEVO's Avatar
Nope... still waiting on you to test one
Mikey
Old Jan 25, 2011 | 09:33 AM
  #185
06MREvo's Avatar
Mikey
haha...damn it Mikey!
Old Jan 25, 2011 | 10:14 AM
  #186
You should have known
Mikey
Old Jan 25, 2011 | 04:56 PM
  #187
Don Q's Avatar
Whats the difference between the GT and the GTX versions? I see alot of people are criticizing that these turbo housing's go the opposite way as the stock one, but aren't all GT turbos this way in the first place
Also, aren't those numbers a little low? I mean, they are on E85... Those are HKS GTII on E85 numbers... I was expecting quite a bit more.
Old Jan 25, 2011 | 04:57 PM
  #188
Don Q's Avatar
Also, what's up with this turbo? Any info would be appreciated. Keep in mind I know almost nothing about turbos .
http://www.atpturbo.com/mm5/merchant...gory_Code=VEVO
Old Jan 25, 2011 | 08:01 PM
  #189
06MREvo's Avatar
The setup ATP had on the test car wasn't that great. Its not really the direction of the goes its how its made with the hard angle of the hotside not allowing perfect flow. GT turbos have a stock inlet compressor housing. GTX turbos have the Garrett 4 inch inlet compressor housing with anti-surge ports....
Old Jan 25, 2011 | 08:04 PM
  #190
06MREvo's Avatar
^^that turbo works with a stock exhaust manifold but obviously can not use a stock downpipe...
Old Jan 26, 2011 | 07:27 AM
  #191
Don Q's Avatar
Thanks alot for the info! However, what do you mean by the setup not being that great? Do you mean the supporting mods on the car?
Old Jan 26, 2011 | 07:56 AM
  #192
ct9asilver's Avatar
Unnamed 272 cams, that most likely are HKS 272's which are crap cams, unported exhaust and intake manifold, stock throttle body which I guarantee was leaking at the seals during the test, an unknown brand 3 inch intercooler which COULD be choking the larger turbo, stock upper IC pipe which may or may not be a problem depending on if they are using stock couplers or not, and no reference to the boost level on the "HIGH BOOST E-85 TUNE"
Thats's what he meant about the setup not being that great
Old Jan 26, 2011 | 09:30 AM
  #193
06MREvo's Avatar
Exactly No name cams, unported stock mani, stock UICP...The stock intake mani & TB are probably alright, as I've seen plenty cars make good power with those...Also the dyno chart above is from a GT series turbo not even a GTX, so there should be some more gains there...The peak tq is pretty nice but it drops off pretty bad...
Old Jan 26, 2011 | 09:56 AM
  #194
juanmedina's Avatar
The GTX will not peak up any spool according to the comparisons on Subaru but it will make more power , the response is also greatly increased.
Old Jan 26, 2011 | 10:22 AM
  #195
Don Q's Avatar
Thanks for the info! I would like to know how does this turbo compares to an FP Red in terms of power and spool up? Would this be a nice turbo for 93 pump on a stock block with:
ETS 3.5 FMIC w/pipes
GSC S2 Cams
Megan 02
Perrin TBE
Ported exh. mani
PTE 1000
