which turbo with the 2.2l?
Old Dec 20, 2010 | 01:09 PM
RockmanX's Avatar
Originally Posted by JmanMR
i guess i will start looking for the best 2.3 kit
now your talking LOL.
Old Dec 20, 2010 | 01:13 PM
xceler8rob's Avatar
I've been getting all my parts from MAP for my 2.4 that I'm building myself right now and I'm building a buddy a 2.3 for his 6bolt dsm. Shoot them a call and they will work out a deal for you.
Old Dec 20, 2010 | 02:45 PM
BiFfMaN's Avatar
Reason why some 2.2 set-ups are expensive is because of Internals used.
If you wanted to do a Billet crank 2.3 or 2.4. It would start to get just as costly as a 2.2.
I would ask what you will be using your car for?
If your going to daily drive your car with the occasional Drag or Auto X, then a 2.3 or 2.4 should be good..good street motors.
If your going to Drag race for competition..then most would recommend the 2.1 or a built 2.0
For serious track duty or time attack. Most teams use the 2.2 set-up off the 4G63 block. Its the compromise motor when you need RPM and displacement.
We could argue all day long about how long motors last...but alot of things can come into play regarding engine life. And not enough information to properly get a accurate account on who's engine lasted longer.
Old Dec 20, 2010 | 02:48 PM
JohnBradley's Avatar
Something that can make peak power in the range you want it. If you want a 4k to 8k motor you need something other than a 3586. If you want a 5-9k then that turbo might work well. Power goals vs powerband is how you need to decide any turbocharger choice. What are you looking to do?
Aaron
Old Dec 20, 2010 | 04:45 PM
JmanMR's Avatar
Aaron
i'm just looking to build a fun street machine. i'm avoiding big turbos because i dont want to have an issue with the lag. thats why i'v been leaning towards the bbk-b. or something related to the bbk-b. i'v been researching like crazy the past 4 months trying to determine a good setup
Old Dec 20, 2010 | 05:00 PM
BiFfMaN's Avatar
you also still on the stock clutch and 6 speed tranny?
your running into the same issue as alot of us "with great power comes great spending"
Old Dec 20, 2010 | 05:09 PM
RockmanX's Avatar
to much damn spending in most cases. I ran into the famous SINCE YOUR ALREADY IN THERE MIGHT AS WELL bug and it only makes sense to do it then and there so your not double playing for labor
Old Dec 20, 2010 | 05:22 PM
JmanMR's Avatar
my quatermaster crapped out, so now i'm in the middle of doing a new quartermaster clutch and timing kit
Old Dec 20, 2010 | 05:49 PM
BiFfMaN's Avatar
Well like mentioned before... keeping the stock block is a good platform to build a 2.3L cheap. It would be down to what company you get the componets from.
Sounds like you are looking for a turbo in the small/stock frame range. Like BBKB, HKS 7460 or FB black. 450-500 hp range correct?
too early for me to recommend the new Borg warner EFR turbos..but they show promise with a price.
Old Dec 20, 2010 | 05:51 PM
BiFfMaN's Avatar
GSC does make a kick A$$ 2.2L stroker kit...Billet parts if you dare to push the limits.
Old Dec 20, 2010 | 06:08 PM
JmanMR's Avatar
i'm lookin to be in 500hp range on e85 with a wicked powerband. i havent found many people using the gsc 2.2 kit
Old Dec 20, 2010 | 06:30 PM
38six's Avatar
You don't see to many 2.2 bc of the expense, for what you seem to be looking for a Buschur 2.3 seems right up your alley.
A 2.2 is more for a wide pwr band to be used for something like road racing/ drag racing, or someone that can't make up their mind on hp range or if they want a race car or street car.
Old Dec 20, 2010 | 09:14 PM
BiFfMaN's Avatar
Nils used to use the GSC 2.2 kit... then got a brand new AMS 2.3RR.
sierra sierra evo uses the 2.2l cosworth IIRC and the cyber Evo has the Tomei 2.2l
You dont hear about them because i dont think they come to this site and brag like everyone else.
Old Dec 20, 2010 | 09:33 PM
JC evo1's Avatar
Originally Posted by Tonba
A mate of mine is using a HTA3582R twin scroll kit. Makes awesome power! 500hp on 28psi (e85). Ballistic to drive!
whos is this? Can you post the dyno sheet?
Old Dec 21, 2010 | 12:16 AM
BLKCarbonEVO's Avatar
Seems a bit low to me... I have a FP Black on 25psi making 612hp on E...
Mikey
LSs1Power
34
Nov 27, 2016 11:35 AM
Llew
Aug 19, 2016 09:27 AM
EvilEvolution8
34
Apr 12, 2016 02:36 AM
Sl33PR_X
Feb 14, 2016 03:51 PM
_Evoke_
19
Jan 5, 2015 06:42 AM
