Bad lifters?
Old Dec 17, 2010 | 01:24 PM
MR BURTON69's Avatar
Bad lifters?
I had some FP4R cams installed recently and now I am gettin a lot of valvetrain noise. It doesnt make any noise at idle, and is the worst when it is cold between 2500 and 3500 RPMs. Once it is above those RPMs the sounds seems to go away and it is not quite as bad when warmed up. I have researched and I am almost positive that it is lifter tick. But it hasn't gone away, could this be a collapsed lifter? Also, would it just be better to replace my lifters? If so, which lifters seem to be good. Seems like alot go with JAM lifters and MAP also sells some ITM ones. Anyone used either of these and have any feedback? Thanks for the help!
Old Dec 18, 2010 | 09:18 AM
Bump
Old Dec 20, 2010 | 07:04 AM
Bump
Old Dec 20, 2010 | 07:09 AM
gsrboi80's Avatar
Were they bled when the cams were done?
There is even a sticky at the top of this sub forum
Old Dec 20, 2010 | 07:13 AM
KarmaSRT's Avatar
I had the same problem I put kelford 280's in my car then the tune shop said they wouldnt tune my car because it was getting a knock somewhere in the valvetrain. So it could be a collapsed but most likely its not. I'm pretty sure mine was collapsed because I had a lot of ticking at idle and when I reved up to 3000 RPM it got worse. I just bought a pair of jam lifters and they quited down a good amount.
Old Dec 20, 2010 | 07:45 AM
I have mine tuned and it shows zero knock. But it is hit and miss with the ticking some days are worse then the others. Where did you pick up the jam lifters?
Old Dec 20, 2010 | 08:00 AM
gsrboi80's Avatar
WERE THE LIFTERS BLED ON INSTALL?????
There is also a procedure for in car bleeding that consists of slowly ramping the throttle to 3krpm holding it there for 10 sec then lift and repeat 10-20 times or so.
Do these before you go spend money on new lifters that you do not need
Old Dec 20, 2010 | 08:04 AM
I believe the tech bled them on install yes, and I have tried the other procedure and it didnt help. This is why I believe I may have a collapsed lifter and I dont want any problems down the road.
Old Dec 20, 2010 | 08:09 AM
KarmaSRT's Avatar
I bought them straight from jam look up jackson auto machine they are in baltimore MD they arent far from me but they are doing the lifters for 165 + shipping look em up .
Old Dec 20, 2010 | 08:32 AM
I will take a look, Thanks!
Nightbreeze
Feb 28, 2016 10:04 PM
ilikeppie
26
May 31, 2012 01:52 PM
millsyy17
31
May 17, 2010 03:05 PM
justboosted02
Jan 29, 2009 11:59 PM
kdublancer
Lancer Troubleshooting
Aug 18, 2008 03:37 PM
