Boost drop off new intercooler
Old Dec 23, 2010 | 05:38 PM
akinnear03's Avatar
I just installed a new buscher streetcore and on my test drive I got up to ten psi then it would drop right off .my hallman controler is set to 10 psi and we double checked all piping conections . Any help would be great
Old Dec 23, 2010 | 05:42 PM
David Buschur's Avatar
You have to have a leak if the boost was going higher than that before. Where did you install the boost input to the manual controller after installing the intercooler and lower pipe kit?
Old Dec 23, 2010 | 05:44 PM
akinnear03's Avatar
I set the controller to ten psi when I put it in and it held fine unroll I put the intercooler in tonight
Old Dec 23, 2010 | 05:48 PM
akinnear03's Avatar
I had the controller on with my stock intercooler
Old Dec 23, 2010 | 05:49 PM
akinnear03's Avatar
The input line is on the upper intercooler pipe
Old Dec 27, 2010 | 07:30 AM
You either have a leak in a coupling or the boost controller has a problem.
Old Dec 27, 2010 | 08:22 AM
ETS Michael's Avatar
The easiest way to find the leak is to build a boost leak tester. It's very simple or you can purchase one from a vendor who makes one. I think STM sells one.
It's a coupler that matches your turbo inlet size and a pvc cap. You drill a hole into the pvc cap and use a push type valve stim. Once you get the tester made make sure the car is off, take off the intake and then pressurize the system. It will be very easy to listen to for a leak without the car running.
Good Luck!
Here is a link to a DIY: http://www.vfaq.com/mods/ICtester.html (This is from my early dsm days)
Thanks,
Michael
Old Dec 28, 2010 | 06:53 PM
akinnear03's Avatar
Thanks guys the lower hose was leaking tightened it up . Now everything is a ok. She's running great now
sssr20det510
13
Dec 9, 2014 10:39 AM
newcomer81
Apr 1, 2010 07:35 AM
IAmADirtDude
21
Jun 12, 2008 04:21 AM
Sgt Blamo
Dec 4, 2005 01:26 PM
en1gma19
10
Nov 14, 2005 10:44 AM
