NEW Rear Differential Upgrade from TRE
I wonder how many people really need this? We have over 650 drag race launches on our diff and it doesn't show any signs of bearing slip. Maybe we just don't make enough torque with the stock turbo....?
So I stop by TRE this week and he showed me a newer version of the HD Side Cover upgrade that Im getting. All I have to say is…… WOW!!!
*Its as light as the stock cover
*Latest aero extended tip design for tumbling the oil for better cooling
*Large taper roller bearing for failure free operation and better axial and radial thrust loads
*Larger A/R ratio housing with surge ports - better oiling distribution inside
*He said this thing is bullet proof and not to mention sexy as hell
Sorry that was a joke, Referring to it as a turbo. We joke about calling it GT150-R
Here's the new link
HD Side Cover Upgrade
Just posted the link and now for car ****
Here's the new link
But none of them have this new side cover. Now don't get me wrong, we send a LOT of stuff to Jon and he does incredible work. Obviously there is a deficiency that this part makes better, i'm just not sure at what level it becomes money well spent. Sub 1.5sec 60' times or 500+ ft/lb track cars...maybe?
Is there a very generic how-to to install this part? Or is it just unbolt the rear diff, etc and it's right there to take off the stock on put on the new?
And is the focus of this part for protecting the differential during clutch dumps only? That's what the website link seems to be implying. ie, for coming out of corners WOT etc this part doesn't come into play? I never really launch my car..
From personal experience,
Jon disassemble my differential right in front of me. I personal saw the bearing fall off the diff with out any aid of a tool; I’ve watch more then my share of Evos break the rear differential. Why do you think companies offer a whole replacements differential for the Evo. Jon isn’t doing this because it’s some sales gimmick. He sees what is wrong and finds a way to fix it. Jon also consults with other engineers and people in the same trade to help confirm his findings. This fixes a very crucial issue. If you don’t want it then direct the negative energy elsewhere. Ultimately it’s your money, do what you want with it. No one is cramming this down your throat, but from what I’ve seen I’m sold and will be having him install this on my personal Evo.
If you know how to properly preload a rear diff then you should be able to do it yourself. But if you don't… I would leave it to the experts.
Lots of the damage is done by launching a car. Even if you don't launch the car you will still see the bearing start to get loose because the wall that holds the bearing is just too thin.
agreed, and same for the car that won the 3 years previous to that.
Thank you
Maybe you could help us out since you've obviously experienced this problem. How much torque/power are you making? What are your normal 60' times? How many launches had you done before your bearing fell off?
The fix TRE conceived and now offers is a replacement side cover that is stronger and allows the use of a larger bearing.
