help P0170
Old Jan 5, 2011 | 04:54 AM
BEISSEN's Avatar
help P0170
Ok I got the issue so far fixed with my other code P0505 and this was a code with it but clears up and I think was masked by the other code. I replaced my TB aperture shaft seals, intake Mani to tb gasket, IAC Motor and cleaned the TB to look like new as well. I had the sas mode via evoscan 2.5 reset and the biss screw was adjusted and set at 850. Now the P0170 code is back, I have not found any leaks and I do have larger injectors. Im running fic 1050cc inj and my tuner thinks it might be that the injectors need to be scaled down some more. I tend to backfire 1-2 2-3 and 3-4 shift at low rpms when its warm. I searched and no definit solutions have been mentioned.
Old Jan 5, 2011 | 03:22 PM
hboy7777's Avatar
what do the fuel trims look like?
Old Jan 6, 2011 | 02:56 AM
BEISSEN's Avatar
I don't know to be honest. I don't have evoscan nor know how to use it.
NJ_evoIXgsr
Apr 15, 2017 09:07 AM
SavageGSR
May 15, 2016 08:36 AM
Dwilson36
May 5, 2016 11:05 AM
bnr34rb26dett
Oct 6, 2015 01:09 PM
EvoIXJDM
Sep 10, 2008 10:54 AM
