P0170 shortly after tune
Old Apr 12, 2017 | 05:05 PM
NJ_evoIXgsr's Avatar
Veteran: Navy
From what it looks like its a fuel trim issue.
I didnt have any codes prior to my recent upgrades then have since got misfires and now this code. The tuner/mechanic went straight to the o2 sensor as my issue.
I would like to confirm on here.
He installed
Pte1000 injectors
New valve cover
Spoolinup cop
1step colder injectors
71hta with map exhaust manifold
Did a boost leak test and cleared that up and finally a tune.
I just got the car back on saturday and the issue showed up today. i have been having issues since the change where i would come to deaccelerate at a light or traffic and randomly car would shutdown. this happened to me twice since the last tune.
After the tune, he had to set it safe because of detonation due to possibly bad injectors. on the dyno you can see dips on hp but torque had no hiccups since tq is down low. he tested by compensating tune to be rich and afr to near 10 and saw 1 detonation/knock vs 15 afr 11~.
Anyone think they have a legit diagnosis?
Any info is appreciated!
Old Apr 12, 2017 | 05:23 PM
darrell's Avatar
Who tune your car is a reputable shop that know evo
Old Apr 12, 2017 | 05:54 PM
Veteran: Navy
Its not a big name shop but a ton of evos and subarus at his shop and often.
Old Apr 12, 2017 | 11:42 PM
RightSaid fred's Avatar
That's a problem right there.
But the real problem will be something you've forgot to mention, like the fuel pump or FPR.
Old Apr 13, 2017 | 08:50 AM
LetsGetThisDone's Avatar
Fuel pump and FPR are the issue.
1. go back to OEM plugs
2. the tune is the issue, and you should find a new tuner. You're in Jersey, so STM or CBRD probably aren't too far from you.
Old Apr 14, 2017 | 07:41 AM
Veteran: Navy
Went back to the shop and found the Fuel trim showing up with -12.####.
Brand new PTE injector is faulty and we were planning to get them sent out to be cleaned and flow tested.
Faulty Injector dumping too much fuel.
Old Apr 14, 2017 | 11:07 AM
Well that could cause it too. Glad to see they gave it a closer look than just saying O2 sensor. The fuel trim being maxed is why you got the system rich code. If the O2 sensor was bad, you would have gotten a code for that.
Old Apr 15, 2017 | 04:31 AM
well of course, the same as everyone else.......too much fuel pressure at idle.,
Old Apr 15, 2017 | 09:07 AM
How do you come to that conclusion when he found a bad injector?
ralliartRA
Jun 12, 2014 03:26 PM
pwnstar
Nov 9, 2011 01:03 PM
Lance Dogg
44
Oct 11, 2011 08:19 PM
EarsLikenElf
Apr 11, 2005 03:30 AM
dropkick
Jan 21, 2005 02:20 PM
