New BW EFR Turbo Thread
Old Oct 2, 2012 | 04:57 AM
  #2041
-Totenkopf-'s Avatar
Originally Posted by R/TErnie
Who did you guys buy your turbos from? I would start asking the people who YOU paid money to.
Have asked this for the last two years. The goal posts keep changing, I doubt even Borg Warner know when they will have availability of these turbos (or at least they aren't telling anyone). The latest when I asked about 4 or 6 weeks ago was that they should have it this month.... Well, I can only hope.
Old Oct 2, 2012 | 05:01 AM
  #2042
SDevo13's Avatar
I've heard november is when a ton of them are coming in. But its all hear-say
Old Oct 3, 2012 | 02:20 AM
  #2043
Talx's Avatar
As I mentioned I have been talking to the shop for almost two years now and they give me the answer they get from Full-Race which apparently after talking to them again is officially there source for the turbo
every time we get to a release date they just give you another one. I could not imagine what could have caused for such a big back order on the turbo, there was some talk about the ss housings but surly that isn't a problem that would take two years to solve there must be something else in the equation that we are missing ore are not being told.
I don't understand why BW can't keep us more informed since by their hands and there distributers they have sold a bunch of turbo's they have not manufactured yet and aren't capable to deliver to the end customer
Old Oct 4, 2012 | 11:16 AM
  #2044
evosdad's Avatar
looks like Monday will be the day to dyno.
anyone looking for anything in particular?
unfortunately it will not be on a dyno jet as R/T and Geoff have used. it will be on a superflow, which reads the same as our local dyno jet.
Old Oct 4, 2012 | 01:24 PM
  #2045
JARVEVO8's Avatar
Good luck!! Hopefully I'll go next week...
Old Oct 4, 2012 | 01:30 PM
  #2046
R/TErnie's Avatar
What I'd like to see...
Same boost, same tune, same fuel....
Overlay a 2nd gear pull , 3rd gear pull, and 4th gear pull. All pulls starting from 2k.
Do the same but start at 4000 RPMS in 2,3,4.
What I think would be useful for comparisons against my setup...or to add to the level of confidence in the data....
18-20 psi pull on your fuel (pump or E85?)
25psi at redline pull on your fuel.
Old Oct 4, 2012 | 01:48 PM
  #2047
Texas_Ace's Avatar
This would be some interesting data. If possible uploading the raw dyno files would be nice as well so we could compare them by time and other methods. If you need someway to upload the files I can host them.
Old Oct 4, 2012 | 01:52 PM
  #2048
R/TErnie's Avatar
Or if evodad gets the run files I can overlay them against mine as well and post them up... same as I did for Geoff's 8374
Old Oct 4, 2012 | 03:25 PM
  #2049
evosdad's Avatar
I'm on E-85, spuds good I will do these on Monday.
My intake manifold is my restriction right now.
Last night on DSMlink I logged 62lbs/min @ 33psi.
Also keep in mind that my car has mad tyte jdm gearing.
Old Oct 4, 2012 | 03:31 PM
  #2050
R/TErnie's Avatar
what size injectors and IDC?
my ID2000's were at 70% @ 300kpa on E85... 11.8:1AFRs
Old Oct 4, 2012 | 04:24 PM
  #2051
evosdad's Avatar
68%
i have 2150cc FIC, with a single walbro 400. what pump are you running?
Old Oct 4, 2012 | 07:52 PM
  #2052
Talonboost's Avatar
Do you mean close-ratio gearbox or what?
Old Oct 4, 2012 | 09:30 PM
  #2053
evosdad's Avatar
Yes, revving to 7k rpms 5th gear ends at 135mph.
Old Oct 4, 2012 | 10:28 PM
  #2054
R/TErnie's Avatar
Evosdad,
I'm running twin walbros at 55psi base pressure.
Are you logging fuel pressure? I would think that pump can't keep up with this turbo... Especially at 30psi (base pressure plus this 30psi)...and furthermore at that IDC on injectors that big.
Old Oct 4, 2012 | 10:36 PM
  #2055
evosdad's Avatar
I can not log fuel pressure. My base is 40psi.
