New BW EFR Turbo Thread
Old Dec 7, 2012 | 12:53 PM
  #2296
Mark S's Avatar
Originally Posted by project_skyline
480hp at the flywheel from 37 psi? Seems fairly low.
Its at the wheel 480hp its 612hp at the flywheel.
Mark
Old Dec 7, 2012 | 10:20 PM
  #2297
Dave W.'s Avatar
2.4 pressure ratio is 20.5psi.
Old Dec 8, 2012 | 03:40 AM
  #2298
kutija's Avatar
I think on the graph it's not absolute pressure so this is around 37 psi of boost.
Old Dec 8, 2012 | 05:25 AM
  #2299
chetrickerman's Avatar
Veteran: Army
2.4 bar is 35.28 psi.
pressure ratio is defined as the ratio of the stagnation pressure as measured at the front and rear of the compressor
Old Dec 8, 2012 | 06:23 AM
  #2300
Texas_Ace's Avatar
I am curious, he made 612whp in the earlier dyno he posted at an unknown boost level.
He then posts the 480hp dyno showing 2.4bar boost (or as pointed out above, ~37psi).
So how did he go from 480whp @ 35psi to 612whp? Didn't look like the turbo had much more boost in it, so where did the extra power come from?
Something is not adding up IMHO.
Old Dec 8, 2012 | 07:29 AM
  #2301
Talx's Avatar
He then posts the 480hp dyno showing 2.4bar boost (or as pointed out above, ~35psi).
this is why
Mark
Old Dec 8, 2012 | 08:39 AM
  #2302
Texas_Ace's Avatar
Originally Posted by Talx
this is why
Ahh, Missed that, didn't see there was another page.
Old Dec 8, 2012 | 02:15 PM
  #2303
Talonboost's Avatar
Mark
Ok, academic question here: 480 is about 21.57 percent off of 612. That sounds pretty reasonable to me. Can anybody explain how this is arrived at? Does it somehow come from measurements on the particular car in the test? Or is this more like a rule of thumb that is arrived at from other data? Or what?
Old Dec 8, 2012 | 10:08 PM
  #2304
Ang Wen Yan's Avatar
Dyno Dynamics workout loss by having a ramp down run after a dyno run is conclude to figure out the mechanical drag and add it back into the on wheel figure to obtain flywheel hp
Same goes to Dastek dyno
Old Dec 8, 2012 | 10:32 PM
  #2305
JohnBradley's Avatar
So for fun and profit figure out how many BTU 132bhp lost through the drivetrain is and how fast it would heat 3 quarts of 75/85
Old Dec 8, 2012 | 10:39 PM
  #2306
n2oiroc's Avatar
i dont buy a static % of loss. i think its really close to a fixed # with a small multiplier. say 40hp loss x .05% for each additional horsepower added.
Old Dec 8, 2012 | 11:07 PM
  #2307
Talonboost's Avatar
During that ramp down I suppose you have to put the clutch in or put it in neutral to remove engine drag, then the dyno can figure out how much the drive train is dragging? - wait a minute, that's just drag with very little load, right? I guess I don't get it. How does that tell you how much power is lost when the whole drivetrain is under full load?
Old Dec 8, 2012 | 11:46 PM
  #2308
bsh's Avatar
bsh
I believe there is no way finding engine power unless you have it on a engine dyno. Use the dyno as a tool and use the same dyno to compare if you have done changes.
Old Dec 9, 2012 | 01:35 AM
  #2309
Talx's Avatar
not only that, but also there is a large amount of power lost because of the friction between the tires and the dyno rollers
by the way a loss of 132 hp which is about 100 KW is enough energy to probably melt the transmission, so I wouldn't think that there is such a large amount of energy absorbed into the drive system
I have never really calculated the dynamics of a dyno but if I would have to guess from my experience I would assume that lose of power is more of an exponential graph of percentage loss, meaning the more power you make the less you lose up to a limit. people are using a liner calculation with the percent of loss as the divergent which in no way models the realistic situation
Old Dec 9, 2012 | 05:39 AM
  #2310
Texas_Ace's Avatar
HP to BTU calculator : http://convert.web-max.ca/index.php?select=58
132hp = 5602.08 BTU/min
Or 93 BTU/second.
So over a ~7 second dyno pull it is putting 650 BTU's into the drivetrain.
For anyone not fermiluar with BTU's, a BTU is how much energy it takes to raise the temp of a pound of water 1 degree.
So 650 BTU's is in theory enough energy to raise the temps of all the drivetrain fluids a few hundred degrees in a single dyno pull.
Only way I trust crank HP numbers is if it is on an engine dyno.
