Evo Ix under power
Old Jan 10, 2011 | 07:55 AM
Evolutionary8's Avatar
Evo Ix under power
I have an Evo Ix mr
Bigger intercooler
Aem cam gears
Mbc
Hard pipes
Megan Cat back exhaust with test pipe
Megan exhaust manifold
The car has not been tuned.
I feel like the car is under powered because when I'm at 18 psi and I drop from 6th to 4th on the highway I don't feel the torque like I'm used too. The turbo still spools and the car picks up but it takes a long time to spool and it doesn't pull you into the seat as it should. Could this be due to the big front mount? Or not being tuned? Or both?
Old Jan 10, 2011 | 08:04 AM
Jrah2987's Avatar
Veteran: Air Force
Kind of a vague questions... check for boost leaks, spark plugs, compression test, etc. then seen where you're at.
Good luck.
Old Jan 10, 2011 | 08:06 AM
Good luck.
Boost leak was the first thing that came to mind because a t clamp on my lower icp broke the other day. Would it still show 18lbs on my gauge if there was a leak?
Old Jan 10, 2011 | 08:11 AM
one4's Avatar
that exhaust mani sucks imo...and a tubular mani will spool slower than a stock on a stock turbo. u also will loose psi untuned with a fmic. get a ported stock exhaust mani, and a tune.
Old Jan 10, 2011 | 08:14 AM
Would it be worth it to keep the Megan mani if I'm buying a bigger turbo? What would you reccomend for a bigger turbo? Nothing FP for now, I'm thinking <800
Old Jan 10, 2011 | 08:23 AM
Jrah2987's Avatar
Veteran: Air Force
I've never had it, but I have only heard bad things about the Megan manifold.
A tune does wonders to any evo (stock or modified) and any tuner will be more than happy to check your motor health before they tune (some insist on it).
FWIW - I'd find the nearest reputable tuner and take it in.
Old Jan 10, 2011 | 08:31 AM
one4's Avatar
naw itll prob crack under the heat. depends what u are doing, daily driving, drag, auto x, road racing...id send your turbo in to fp to be converted to a green or cbrd to be made into a bbk... or stick with the stock turbo, get it ported, get everything else ported, cams, and get a tune! the 9 turbo is awesome. im running 25psi on 91oct and 30 on e85.
Old Jan 10, 2011 | 08:55 AM
Bryant05TB's Avatar
+1 on taking it to be tuned...i've also read nothing but bad reviews on the megan manifold, check that thing for cracks and if its not the mani then just do a boost leak test ...and there are a lot of options with the IX turbo best of luck to you OP
and in regards to your question about keeping the megan mani- Many builders have made crazy amounts of horsepower on the stock ported mani, so that's the route I'd go. Just my two cents.
Old Jan 10, 2011 | 10:38 AM
Thanks for all the help guys! I'm bringing it into RS motors in Burnsville MN,
Old Jan 10, 2011 | 10:42 AM
Bryant05TB's Avatar
Keep us updated...and the best of luck to you
Old Jan 10, 2011 | 11:17 AM
I still have a stock Evo 8 manifold, could I port that and use it on my 9? Also is porting basically just boring out the pipes so the wholes on the gasket and the wholes on the manifold are exactly the same size? Also I have two o2 bungs on the manifold to insert air/fuel sensors. Would I get more power by taking the bolts out and making like an o2 dump?
Old Jan 10, 2011 | 11:38 AM
Jrah2987's Avatar
Veteran: Air Force
Lots of shops will port it for you. Just ship it out to Buschur Racing... i think it's only like $100 or something.
EVOII
10
Feb 25, 2016 11:09 AM
740 Turbo Brick
Oct 21, 2015 05:32 PM
MisUnderStood
Mar 15, 2013 12:38 PM
codyd66
13
Aug 28, 2012 07:04 PM
getsideways
May 24, 2009 05:28 PM
