Help! What´s the right 1st synchro for VII?
I´m rebuilding my gearbox due to previous owner abuse, and got stuck on the 1st/2nd synchros. According to ASA, the right part is MR581432 but everybody kept telling me to buy MR581385, and so I did. But that was the wrong part.
My Evo VII stock synchro is on the left, and the new ones (MR581435) on the right. Any clues on the right part number? Thanks in advance!!
When I just looked it up it says everything from 12/2002 and down should be the MR581432 like you came up with. I saw the old part number then it crosses to the 581432 now. Not too many 7s floating around so I am no better than what you already have
aaron
aaron
For my personal Evo 7 ( MJ2002 ) the following Part numbers comes in: ( approved a few times due to revisions for customer transmissions )
used up to 12/2003 for Europe, Japan, South America...
New parts used together:
1st Ringset MR 581432
2nd Ringset MR 581432
Sync spring 1+2 MR 581387
Sleve 1-2 MR 581384
Old Part numbers:
1st Ringset MD 748059
2nd Ringset MD 748059
Sync spring 1+2 MD 748670
Sleve 1-2 MD749220
If you send me your VIN number, i can find the right parts for the VII
Steffen
Sleve 1-2 MR 581384
Old Part numbers:
Sleve 1-2 MD749220
Steffen
Sleve 1-2 MR 581384
Old Part numbers:
Sleve 1-2 MD749220
Steffen
Sleve 1-2 MR 581384
Old Part numbers:
Sleve 1-2 MD749220
Steffen
1st ring assy - MR581382
2nd ring assy - MR581382
1/2 sync spring - MR581387
1/2 sleeve - MR581384
3rd ring assy - MD770348
4th ring - MD748058
3/4 sync spring - MR581389
3/4 sleeve - MR581388
5th ring - MR581382
rev ring - MN168936
5/R sync spring - MR581383
5/R sleev - MN168859
rev gear - MD749430
Thats different from mine numbers i am using:
Sleve 1-2 MR 581384
4th ring - MD748058
5th ring - MR581382
rev ring - MN168936
5/R sleev - MN168854
rev gear - MD749430
Sleve 1-2 MR 581384
4th ring - MD748058
5th ring - MR581382
rev ring - MN168936
rev gear - MD749430
Hi all,
I'm using an evo IV RS gearbox w/ part no. MD975148 and code: W5M511Z6A1 w/ final drive ratio of 4.875.
I hv gritting between 1 and 2 & 3 and 4.
Can someone point me to where I can get the replacement stuff to fix my problem.
Also, which of the above part numbers would be corresponding to mine?
Hi all,
Hi all,
1st gear ring - MR581432
2nd gear ring - MR581432
1/2 spring - MR581387
3rd gear ring - MD770333 (1996.08.1 - 1996.10.3)
3rd gear ring - MD770348 (1996.11.1 - 1997.06.3)
4th gear ring - MD748058
3/4 spring - MR581389
LCS,
I'll be taking down the box this weekend and taking some pics (don't know if that will help) for clarity.
I prefer to get the whole set to do the repair, as in, set 1 (1st to 2nd), set 2 (3rd to 4th) and set 3 (5th and R).
Do these sets have a number or I have to request quote for individual numbers like what you have given me.
My mechanic also says that I need to get the hub for the sleeve. Would this be another numbered item.
