Tcase/tranny/diff fluids
Old Jan 12, 2011 | 06:17 PM
silverguy's Avatar
Hey guys.
So my Tcase went bad a couple weeks back and Im now swapping it out.
While the car is jacked up I figure, why not change all the fluids while im down there. I researched the fluid for the tcase and from im hearing the Diaqueen GL5 LSD gear oil is the best stuff.
I want to hear others opinion on what to put into the tcase, tranny, and rear diff.
also if there is a certain way to change the tcase oil, the tranny oil, and the rear diff let me kno.
pm me or just reply to thread please
Old Jan 12, 2011 | 06:55 PM
06RedRalli's Avatar
Personally in the tcase and rear diff I only use mitsubishi's diaqueen gear oil.
For my trans I've been using the pennzoil synchromesh.
And the way I fill is by going to NAPA and they have a pump that fits over the 1qt. bottles and I just pump the fluid into the trans and tcase.
Old Jan 12, 2011 | 07:10 PM
silverguy's Avatar
How often do u swap out the fluids?
Old Jan 12, 2011 | 07:26 PM
06RedRalli's Avatar
Every 15,000 for all...prob a bit soon...but I like to keep things well lubricated and new fluids in as much as possible...
Old Jan 13, 2011 | 11:24 AM
silverguy's Avatar
bump anyone else care to give me their take
Old Jan 13, 2011 | 11:26 AM
Kracka's Avatar
I aim for every 15-20k miles/annually.
transmission: Redline cocktail (2xMT90 + 1xMTL for the Evo VIII/IX 5-speed)
trasfer case: Diaqueen 90W LSD
rear differential: Diaqueen 90W LSD
Old Jan 13, 2011 | 11:28 AM
whitedsm97's Avatar
i swapped all my fluids out for amsoil products and have had not regrets. no noise at all from the tc and also shifts are better. when i drained all the old fluids out, i was horrified at what came out of the front and rear diffs. it wasnt even liquidy anymore and just oozed out. from my personnal experience, i like amsoil.
Old Jan 13, 2011 | 11:30 AM
gsrboi80's Avatar
Been covered to death on here but what has worked flawless for me and my abusive driving for over 130k
Pennzoil Syncromesh in the tranny
Diaqueen LSD in the TC and rear diff.
I would not even consider any other fluids.
Old Jan 13, 2011 | 05:30 PM
silverguy's Avatar
Thanks guys
Old Jan 13, 2011 | 05:49 PM
WolfsFang's Avatar
I just got AMSoil for everything so ill see how the car is when i get the fluids.
Old Jan 13, 2011 | 06:05 PM
RSMike's Avatar
http://www.teamrip.com/manual_transm...tion_info.html
http://www.teamrip.com/transfer_case...tion_info.html
http://www.teamrip.com/rear_axle_hyp...tion_info.html
Procedure for refilling the transfer case is very very important as it is very easy to underfill.
Personally i remove the top plate (4x 10mm bolts) and fill through there, a full quart.
Drive for 20mins then pull out the "fill" plug and let it drain to the correct level
Old Jan 13, 2011 | 07:29 PM
silverguy's Avatar
^^^ very helpful thanks
Old Jan 16, 2011 | 01:12 PM
silverguy's Avatar
hey guys will one jug of diaqueen lsd gear oil be enough for the tcase and rear diff? also how much of the pennzoil synchromesh and what grade do i need?
Old Jan 16, 2011 | 02:17 PM
RunThat's Avatar
Motul or Amsoil for all my fluids. Never had a problem and never expect to.
Old Jan 16, 2011 | 02:56 PM
siceclipse's Avatar
good info in this thread
