Evo Bottom End--What's letting go?
Old Jan 16, 2011 | 01:45 PM
  #31
PlanoEvo's Avatar
my IX windowed #3 rod.... bolt ons,cams+e85 32psi stock turbo. Was hitting real hard lots of times then one night 1/4 throttle 3rd gear onramp poof thtats all she wrote 2 nice holes front and backside....will find out what let go when taking apart next month....
Old Jan 17, 2011 | 02:22 PM
  #32
meckert's Avatar
Sorry to hear that brother-- would be interested in what let go-- so post-up when you get a chance and a read out on what went wrong.
Old Jan 17, 2011 | 02:38 PM
  #33
TxEvo8's Avatar
You ought to stop by EvoD and speak with Kevin on the subject, he will definitely point you in the right direction.
Old Jan 17, 2011 | 03:41 PM
  #34
meckert's Avatar
Good Point-- I know Kevin and he has tuned my car in the past. Your right he is well versed and would be a good guy to ask an opinion of.
Old Jan 17, 2011 | 07:05 PM
  #35
BLKCarbonEVO's Avatar
If you don't run your car low on oil your bearings should last, I ran 1/2 quart over so I never had to worry about the oil pickup running dry... also if you keep tq below 400 your rods will last, and last, don't load the car up in low rpms in a high gear. Those are the three best things anyone can tell you.
I ran 540hp stock block for almost 2 years and never had a problem. When we took the motor apart it looked like new!
Mikey
Old Jan 18, 2011 | 10:18 AM
  #36
PlanoEvo's Avatar
thanks jim already have going to do it in my garage with help from some other ntec members.it's the only way I can afford to do it now.
Old Jan 18, 2011 | 10:41 AM
  #37
JohnBradley's Avatar
The majority of failures we have seen are rods. We are beginning to see bearing failures now though. Not sure if its cars that are uncovering the pickup or bad luck. They have been cars that shouldnt be able to pound bearings out, it looks more like oil starvation issues.
aaron
Old Jan 18, 2011 | 03:18 PM
  #38
meckert's Avatar
Thx--was hoping to hear from some of the shops and builders--your comments/insight are /is appreciated. Just trying to get to the specifics of the bottomend failures so I can be educated and prepared in the event a failure comes my way-- doesnt sound like its going to be a simple and cost effective fix--instead you get a complete rebuild. lol. Thx
Old Mar 2, 2011 | 11:14 AM
  #39
PlanoEvo's Avatar
Is there any possible negative side affects to running a 1/2 over?
Old Mar 7, 2011 | 07:45 PM
  #40
PlanoEvo's Avatar
you can look in the NTEC forum under clubs and look for the rebirth begins lots of pics broke the 3 rod in half.
burnzy
Jul 21, 2016 07:35 AM
9GUY9
327
Dec 17, 2013 09:16 PM
Jacks Transmissions
Jacks Transmissions
Jan 4, 2013 12:26 PM
RealStreet
Aug 24, 2012 10:31 AM
craigybaby37
Nov 23, 2011 05:13 AM
