9500 rpm setup?
9500 rpm setup?
Hi...
Is there any special setup for the engine to make 9500 rpm?
2.0L evo 9
-Rods
-pistons
-Studs
-race bearings
-cams
-Balancer shaft
-Valve springs
Special clearance for bearings?
I need some experience please
Regards,
2.0L evo 9
-Rods
-pistons
-Studs
-race bearings
-cams
-Balancer shaft
-Valve springs
Regards,
I would add in a Kigley HLA to your list...helps prevent all of the oil going to your head in the higher rpm's. Also, either an AMS or Buschur oilpan to help keep the oil around the pickup. The rods would also be an area to think about, requiring you to think about the overall use of the car. If it won't be a daily driver or you don't mind replacing/checking the rods fairly frequently compared to steel rods, then some aluminum rods would be beneficial for the lighter weight. A quality steel rod though such as the BR spec crower rods would work though too.
oh and thats just an idea. many similar builds, like mine, are going this route. just need the strongest stuff..
ie. manley turbo tuff's, HD pistons, ported head with awesome valvetrain, and great intake and exhaust system. (pretty much what my build consists of)
konstantinosIX
Jan 19, 2010 10:03 AM
