best stage 2 cams for evo 8
Old Jan 29, 2011 | 12:03 PM
sk8rtilldie's Avatar
Originally Posted by BLKCarbonEVO
Kelford won the cam shoot-out like three ****ing years ago. GSC has made at least 4 revisions that i know of since and now have the absolute best cams on the market. PERIOD. Don't take **** like that to heart. It is old and the car community is always evolving into better products.
GSC S2 FTW!
Mikey
Do the GSC S2's require spring upgrade????
Old Jan 29, 2011 | 12:18 PM
BLKCarbonEVO's Avatar
Yes! I would get the Kiggly springs and while you do that add the Kiggly HLA.
Mikey
Old Jan 29, 2011 | 12:25 PM
KX250Fmotoracer's Avatar
They arent "required" at stock rev limit, but I wouldn't want to drop a valve...
Old Jan 29, 2011 | 12:36 PM
You are right, they are not required, but lets define required... If you have fresh new valve spring you would prob be okay but that is usually not the case. On an VIII they can valve float as early as 6500rpms that I have seen. The IXs tend to hold up to about 7000-7500rpms. Those cams don't really wake up till over 6k. Get valve springs and do it right in the first place. It will save you money in the long run. No one likes to break a motor because they tried to save $400.00. Then you are paying 5k+ to fix a 400 dollar problem that should have been done in the first place.
Mikey
Old Jan 29, 2011 | 06:37 PM
scothu's Avatar
Mikey,
I already ordered the kiggly beehives from the start. Do you think it's necessary to order the Kiggly HLA even tho im not pushing over 400whp, and probably wont ever go over 500whp in the future?
Old Jan 29, 2011 | 06:39 PM
scothu's Avatar
Also, gsc s2 cams do require springs i think... the kelfords 272s CAN be done w/o but its not recommended.
Old Jan 29, 2011 | 07:07 PM
Originally Posted by scothu
Mikey,
It will help keep more of the oil in the pan to make sure your bearings and turbo stay happy. 90% of people that stack bearings and/or have other bearing problems, or snap the rods are due to the lack of oil, high tq, or high cylinder pressure. In some cases all of the above. I like to eliminate as many potential problems as possible. For $150 I would do it, it's a great little mod for the price. If it was like $500 I would say not to worry about it but it is fairly cheap and just adds an extra level of protection in my eyes. It is an extremely easy install too.
It will also help increase oil pressure The stock block will run forever if you take care of it. I run my car 1/4-1/2 quart high too to help ensure that the oil pickup never runs dry during acceleration or hard cornering.
1) Don't run your oil more than 3k miles - even on synthetic
2) Keep cylinder Pressure low - control timing (really only for E85, Meth, Q16 etc..)
3) Keep tq below 400
4) Don't run your car low on oil. I check every time I fill my car up with gas
5) Don't load the car up in low rpms in a high gear like 5th or 6th
6) Don't over rev the car. 7500rpms is the max that I revved my stock motor to. High revs can/will pop a rod bolt = blown motor, and that is no good
These are just my recommendations - different people do things differently. My stock motor I ran on 1500cc of meth and 540whp on a Red for over 1.5 years. I also beat the living **** out of my car. The bearings also looked really good for 50k miles on the motor.
Greg recommends springs for the S2s but there are some people that don't run them, and will usually have problems at some point. This brings us back to the "I like to eliminate as many potential problems as possible" Having a valve fall into a piston will cost you an engine build. Not worth taking a chance when springs are only $400. That is just my point of view on things.
To each his own...
Mikey
Old Jan 29, 2011 | 09:59 PM
VRSF Tiago's Avatar
Not required but strongly recommended. GSC's words.
Old Jan 31, 2011 | 09:14 PM
M_lizar's Avatar
Is the GSC S2 is something I can use for the stock turbo. Or would the GSC S1 suit me more?
Old Sep 28, 2014 | 06:22 PM
D1andonlyantman's Avatar
Holy thread revival batman!
^I was also wondering this. I read that s1's were more suited to a standard turbo but I was told to go for s2's by someone who clearly knows what they're talking about, and because I'm getting forged rods the tuner will be running 1.9 bar boost, so I guess that would make the 274 cams better suited?
midegade
Mar 22, 2017 04:17 PM
JeyEvo
Mar 21, 2016 06:53 PM
EVO(boss)
Jul 4, 2014 02:13 AM
EVO'D8
Jul 18, 2012 05:16 PM
EriCS
Nov 30, 2010 10:55 PM
