thoughts on cutting radiator?
Old Jan 18, 2011 | 09:24 PM
Drill_Sergeant's Avatar
Veteran: Army
in a quest to save $500 and buying a half width radiator,
what are some of your thoughts on cutting an aluminum radiator in half and welding the tanks back up?
i was thinking there might be an issue with the shavings left behind even after flushing.
Old Jan 18, 2011 | 10:11 PM
3grst01's Avatar
Most people go with the mishimoto civic radiator since its twin core and has the same if not a little bit better cooling efficiency than the stock single core radiator and also no shavings to worry about even though the only thing you would have to really worry about with having those is clogging your ghetto rigged radiator which isnt goin to cost you any thing besides your time and welding wire and messing with the water pump life. If you cut it with it facin the ground gravity should help reduce some shavings and you could then run a garden hose through it before welding it. Good luck man.
Old Jan 18, 2011 | 10:12 PM
JohnBradley's Avatar
Common practice. Its all how its cut and how well its cleaned. I think most of what you'd get in left over aluminum would be pretty minimal. We havent had any issues cutting them in half and welding them up.
Aaron
Old Jan 18, 2011 | 10:28 PM
Veteran: Army
thanks for the thoughts
Old Jan 19, 2011 | 09:09 AM
BluEVOIX's Avatar
How much would that cost? What about getting the Koyo Half Radiator instead? I think its around 300.00
Old Jan 19, 2011 | 09:23 AM
JesseB's Avatar
i do it all the time for local guys, works well and lets you customize the radiator to suit an evo alot better than most "civic" radiators.
Old Jan 19, 2011 | 09:26 AM
EvoVIIIFL's Avatar
Its a work of art.. got mine just recently for alittle less shipped.. no complaints here
Old Jan 19, 2011 | 09:29 AM
RockmanX's Avatar
but you also have wielding skills out this world most dont possess. Not fair LOL.
xXVicariousXx
Aug 12, 2016 05:17 AM
walker992
Jun 28, 2016 11:49 AM
Czarcasm
Jan 22, 2014 10:57 PM
Mellon Racing
Feb 28, 2011 01:42 PM
pflores210
Feb 24, 2011 06:32 PM
