ACD Problem-All 3 lights on
Old Feb 2, 2016 | 08:36 PM
  #31
danfalcas's Avatar
Hi, I dont know if u guys are still active in this thread, but I have Evo 7. AYC code 82 and ABS code 32 but ABS light doesnt turns on.
The error started after I replaced the clutch on my evo.
Originally Posted by german_evoVII
If the ABS light comes first, followed by the ACD / AYC lights:
Failure of one/multiple of the ABS sensors ( also broken wires or broken sensor rings possible )
It takes longer time for an Sensor fault to show up at the ACD / AYC system.
If only the ACD /AYC lights show up, but ABS stays off and works:
Failure in Pump Unit
I am rebuilding these ACD and AYC pumps here in Europe, so i am more that familiar with these codes and Errors
Pump Failure codes are almost everytime 80, 81, 82
To track down your issue :
Read the ABS Codes and the ACD codes to verify what sensor does the code.
Evoscan with an 1.3U cable will work ( the evoscan Cable )
If you could not get one ( borrow one ) you will have to let the dealer check it with the MUT III.
Old Feb 3, 2016 | 03:02 AM
  #32
kikiturbo's Avatar
did you bleed the ACD after the clutch change?
joseph143
Jan 23, 2018 09:40 PM
W4r3z
Jan 7, 2018 10:48 AM
Michael Roestel
Sep 21, 2017 08:00 AM
xi
Jun 14, 2017 01:41 PM
suprPHREAK
Toronto Lancer Club
62
Dec 15, 2016 10:17 AM
