Safety on stock block HTA Green or RED
Old Jan 23, 2011 | 07:51 PM
EriCS's Avatar
Whats your opinion in which turbo is safer for stock block on pump gas, the HTA Green or Red? I figure the Red would be with due to the fact the Green has more torque down low??? I have full supporting mods except for a ported TB and intake mani. I am also curious about the 6 speed tranny and the Red?
Old Jan 23, 2011 | 07:59 PM
achilles3000's Avatar
Go black if that's your concern..If you realy want the red just have you tuner ramp up the spool and tq slower and low..The 6 spd tranny is not that bad as long as you don;t bang the crap out of it like I do my girl you'll be fine..The red tends to fail and the green is known to blow up blocks..
Old Jan 23, 2011 | 08:23 PM
raasfaas's Avatar
I personally went with the Red for this very same concern. I too was a little indecisive on which one to get...I had no intentions of building a motor anytime soon so I opted for the Red which will have less stress on the motor tq-wise (although it's all in the tune)
Old Jan 24, 2011 | 05:44 AM
cij911's Avatar
HTA Green makes for a better street car IMHO. You can control torque (if you are that concerned) with ECU controlled boost (e.g. hit at 25psi and then increase to 27 and hold until redline). The HTA Green is more responsive and will produce a broader power curve on pump gas. If you were running e85 or race gas and were going to be running 30+ psi, then the Red would be great.
I'm at ~450+ whp on stock block with my HTA Green. Yes I'd love to have a few more hp, but I don't want to increase lag or sacrifice the transient response - two side effects of the larger turbos....
Old Jan 24, 2011 | 05:48 AM
GreenAWD's Avatar
The HTA Green loves pump from my understanding, and it makes some decent torque numbers. The red will sacrifice some spool but make more power.
As for the 6 speed, run it until it blows as long as you aren't slamming gears hard it will probably be fine. I wouldn't baby it but I wouldn't beat it like a red headed step child.
Old Jan 24, 2011 | 07:41 AM
Jossue's Avatar
HKS7460R?? (just another option)
Old Jan 24, 2011 | 03:59 PM
EriCS's Avatar
Possibility especially since is a bb turbo. I've been hearing about two many red failures for my liking so its either the green, bbk, or possibly the hks. I need to see more data on the hks on pump first.
Old Jan 24, 2011 | 04:35 PM
killerpenguin21's Avatar
subscribed to this one.
i agree the green seems to love pump from what i have seen. im thinking you can tone down the torque spike through tuning? couple sheets have shown 400whp on 23-25 psi with full spool not much later than stock. its hard to pass that up. but at the same time i am in no way looking to build a block any time soon.
Old Jan 24, 2011 | 10:12 PM
McDougal's Avatar
I should know this, but what supporting mods do you need for a green?
Old Jan 24, 2011 | 10:22 PM
Bryant05TB's Avatar
Bbk-b
Old Jan 25, 2011 | 11:04 AM
Jossue's Avatar
I ordered an HKS from Iveytune but i am still in iraq so it will be about 2 months before its gets tuned but it will be on **** 91 otcane until i move to atlanta for 93. I will post numbers I'm hoping it will be worth the wait.
Old Mar 8, 2011 | 08:08 PM
High_PSI's Avatar
If anything the Red would be a safer turbo simply because the torque does not ramp up as fast as the Green. Obviously if you over boost then boom but man the Green has a Stock like spike and then add 100FP's in that stock like curve, you may send a rod through the block. The Red will ramp up less sever and then hold that curve for longer. I believe a Red on 25-29PSI 93 Pump you can live an long and healthy life.
Old Mar 8, 2011 | 08:16 PM
tdubbz's Avatar
tune = reliability. Especially on pump gas, you won't make the torque to have anything to worry about with the stock block with the HTA Green. IMHO of course
GT35MR
Jul 15, 2015 11:30 PM
Wiznaz
Apr 21, 2015 07:01 PM
STWHY?
23
Apr 23, 2012 07:22 AM
tdubbz
Oct 11, 2010 06:41 AM
