Big vs Small throttle body
Old Dec 12, 2012 | 03:50 PM
  #46
JohnBradley's Avatar
In doing some research on rally restrictors recently, I came across some interesting information on 60mm throttle bodies. While not directly the same as a normal restrictor is seems a single 60mm is a choke at 800whp normally. Definitely no harm in going larger, the last one I did jumped a bunch with its most recent retune.
JMS saw 60whp on an already 840whp car with their 906 pull (FP 3794).
Aaron
Old Dec 12, 2012 | 03:56 PM
  #47
Tonba's Avatar
Hmmmmm, very interesting..
Old Dec 12, 2012 | 03:57 PM
  #48
Tonba's Avatar
Has anyone notices a difference in throttle response? Snappier with bigger throttle?? Lazy?
Old Dec 12, 2012 | 04:19 PM
  #49
They can be more prone to bog on tip in.
Old Dec 12, 2012 | 04:20 PM
  #50
Tonba's Avatar
^ Oh?
What do you think is the cause of that John?
Old Dec 12, 2012 | 04:59 PM
  #51
Big air door means it can loose velocity at angle change since percentage of change can be ALOT more air per degree of swing. It can and HAS to be tuned around but it happens to some extent.
Old Dec 12, 2012 | 06:20 PM
  #52
Tonba's Avatar
Hmmmm, interesting... Thanks John
Old Feb 11, 2013 | 02:38 PM
  #53
Svendiesel's Avatar
DIGGIN IT UP. Aaron, since you know my dilemma right now, and Im contemplating the magnus with a 70mm fullblown with 3" ic piping, doesnt that kind of not make sense? lol
70mm is 2.75", and if I want to do 3" ic piping when I do the 6766, wont that 70mm tb be a bottleneck? I should do the boomba75mm right? Since 75mm is 2.9in. Makes a little more sense than a 70mm. Or will it not be that big of a deal?
Old Feb 11, 2013 | 02:49 PM
  #54
Paul Walkin's Avatar
As long as your throttle body is as big or bigger than your compressor wheel, I wouldn't worry about it.
Old Feb 11, 2013 | 03:53 PM
  #55
Svendiesel's Avatar
Presumably the inducer, ya? 6766 is 67mm inducer and 87mm exducer.
EVO 4 life
Nov 10, 2015 08:04 AM
escape1221
Dec 28, 2012 05:16 AM
Blue91lx
Jan 25, 2012 10:50 AM
heavens turbo
May 1, 2010 10:46 PM
TTP Engineering
Aug 29, 2009 12:26 PM
