Ikeya shifter and QM twin review
Old Jan 25, 2011 | 04:25 PM
KentStateTsi's Avatar
Veteran: Army
Thumbs up Ikeya shifter and QM twin review
I've have a little over 500 miles on these since my rebuild. I was a little concerned with the shifter after some of the reviews i've read, especially on a DD. I honestly think people just get tired of adjusting the cables and give up. Yes it is a PITA to get through the instructions. Following the pictures was pretty easy. You have to switch the cables position simply by moving the right cable to the left and left to the right. Make sure you take the 4 bolts holding the ABS computer out and move it up to make sure the cables are switched as close to the firewall as possible. Then reinstall the abs computer. The clutch holds everything no problem. But, it does make a ton of noise! Everydown shift, every slip, when its hot. Seems like all it does. I would give them both a thumbs up if you take the time to install them right.
Old Dec 20, 2015 | 03:24 AM
flabber's Avatar
Ikeya shifter
Do u still have the shifter install and running. Iam go-to buy this very soon .any chance of getting some install pics .
PeteyTurbo
205
Dec 10, 2024 06:04 AM
xPRimNT
239
Jun 2, 2016 10:40 PM
Mitsu.kid.02
Lancer Engine Management / Tuning Forums
217
May 25, 2016 10:47 AM
xmaster19
11
Jan 3, 2016 08:35 PM
