How to recognize bad Idle Control Valve???
Old Feb 6, 2011 | 09:49 AM
rcheung's Avatar
That looks like what happens to mine when I unplug the battery and plug it back and drive with the AC on. It takes time to learn. It might not be the same issue with yours though.
Old Feb 6, 2011 | 12:42 PM
dvd_mi's Avatar
How much should IACV go out when turned on????
Old Feb 6, 2011 | 12:51 PM
4RETECH's Avatar
I have a pic of my bad one here :
https://www.evolutionm.net/forums/ev...ge-my-isc.html
Note: when you reset the IAC, the car will need an idle learn and driven a lot to re-learn how much to progress when coming to a stop. Most of the time it will stall for the first 3 stops,LOL.
Old Feb 6, 2011 | 01:51 PM
dvd_mi's Avatar
I cant see those teeth.
Old Feb 6, 2011 | 03:00 PM
4RETECH's Avatar
I've never seen any teeth. I'm talking about the crack in the plastic.
Old Feb 6, 2011 | 07:13 PM
dvd_mi's Avatar
Can anyone tell me???
Old Feb 7, 2011 | 11:42 AM
barneyb's Avatar
This is from my DSM. Maybe the operation of the ICV is the same on an Evo, maybe different.
On a DSM, the ECU didn't keep track of where the plunger in the ICV was located. The ECU only sent raise and lower signals until the targeted rpm was achieved. When the engine was shut down the ECU didn't know where the ICV plunger was located. So, at start the ECU would command the ICV all the way to the end of travel and then run it back a certain number of steps.
Old Feb 7, 2011 | 08:25 PM
dvd_mi's Avatar
OK, but how much should it go out??? 1/16, 1/8, 1/4 or 1/2 of an inch???
Old Feb 8, 2011 | 06:38 AM
barneyb's Avatar
Its not a question of how far - that is decided by the ECU and will vary car to car. The ICV should operate quickly and not with a loud sound at start. This all has to happen while you are turning the key.
Old Feb 8, 2011 | 02:50 PM
rcheung's Avatar
Lol, did you read my previous post at all ? Some have teeth some dont. Thats not the part of the IAC valve that I've ever seen go bad.
Old Feb 12, 2011 | 09:25 PM
Rojo EVO's Avatar
@ dvd mi - My car is doing the same thing. Have you found a fix for yours? Was it the IAC?
Old Feb 13, 2011 | 02:47 PM
anthonyrb98's Avatar
The best way is to read resistance of the coils
Old Feb 14, 2011 | 11:41 AM
rcheung's Avatar
You mean of the pins.
Old Feb 28, 2011 | 08:09 PM
dvd_mi's Avatar
Replaced IACV. Did not fix the problem.
Old Mar 2, 2011 | 04:58 AM
dvd_mi's Avatar
If I take the IACV out of throttle body and turn ignition on, how much should it move (distance). How many times should it do it???
