How to recognize bad Idle Control Valve???
Old Jan 27, 2011 | 05:57 PM
dvd_mi's Avatar
Is there a way to see that Idle Control Valve is bad by just looking at it???
Old Jan 27, 2011 | 10:35 PM
BLK_EvIL's Avatar
Yup the teeth will be worn down or chiped also leave it pluged in but pulled out of t-body and turn key to on position and it should move out of housing.
Old Jan 27, 2011 | 10:48 PM
My03evo's Avatar
Yeah it's supposed to do a full sweep and then go back to the original spot, right?
Old Jan 27, 2011 | 11:25 PM
Silk's Avatar
Use a multimeter to check the resistance across the pins, I believe it's supposed to be around .3 ohms
Old Jan 28, 2011 | 04:40 AM
dvd_mi's Avatar
I took it out from throttle body, and i could not see any teeth.
Old Jan 28, 2011 | 10:35 AM
barneyb's Avatar
I had the one apart off of my DSM but I don't remember whether there were gears or not. The piston that traveled in and out had a worm drive inside and enough exhaust had condensed on the threads to make it sticky. I could spray lubricant inside and it would work for another month or two before needing more lubricant. This finally got old and I replaced it.
Old Jan 28, 2011 | 11:30 AM
dvd_mi's Avatar
So how can i see those teeth??? I took it out and i dont see them.
Old Jan 28, 2011 | 11:40 AM
Evolution84's Avatar
Does the car idle at all?
If not, Have you tried adjusting the idle screw?
Old Jan 28, 2011 | 11:52 AM
rcheung's Avatar
You can't really tell by the teeth if its bad. I've seen a few IAC valves and when they went bad the teeth looked perfect. This is only on the older IAC valves, the newer ones are smooth and dont have any teeth so you really can't tell by that. In fact I dont even know if the IAC valve is suppose to spin at all or just move in and out. If you do a search , you can find out which two pins to check with a multimeter and to see if the valve itself is bad. I forgot which ones they were.
Old Jan 28, 2011 | 11:53 AM
rcheung's Avatar
Not a good idea without using the idle adjustment button in evoscan.
Old Jan 28, 2011 | 02:33 PM
dvd_mi's Avatar
Does anybody know two which pins.
Old Jan 28, 2011 | 04:10 PM
BLK_EvIL's Avatar
https://www.evolutionm.net/forums/in...motor-bad.html
heres a thread with the info
Old Feb 5, 2011 | 04:47 PM
dvd_mi's Avatar
I just started the car with IACV out. It clicks, but I dont really see anything moving on it.
Old Feb 5, 2011 | 09:51 PM
sunrichmond's Avatar
if its bad it idle really high in a cold start and idle really low when hot,whens its really bad it bounces all over the place
Old Feb 6, 2011 | 04:52 AM
dvd_mi's Avatar
There is no problems when i start it. When I drive and stop the car it is also ok. It idles crazy only when I drive and hit the clutch. That's exactly what's happening:
http://www.youtube.com/watch?v=Bfc_Mbbq_uM
