How to recognize bad Idle Control Valve???
Old Mar 2, 2011 | 07:30 AM
  #31
rcheung's Avatar
Try to find someone with evoscan and hit the activate button for the idle screw and see what the idle goes to.
Old Mar 2, 2011 | 05:08 PM
  #32
dvd_mi's Avatar
If I take the IACV out of throttle body and turn ignition on, how much should it move (distance). How many times should it do it???
Old Jul 28, 2011 | 01:16 PM
  #33
raza21_84's Avatar
This all sounds like its VTA valve on cars with MAF
Old May 9, 2013 | 01:26 AM
  #34
vicariousthrill's Avatar
did you ever fix your issue? having same issue here ever since i switched to a evo 9 bov from a forge =/
Old Oct 24, 2022 | 08:00 PM
  #35
tbruns97's Avatar
Originally Posted by sunrichmond
if its bad it idle really high in a cold start and idle really low when hot,whens its really bad it bounces all over the place
mines idling like 2300 starting and staying there while in neutral car runs fine when driving until clutch is needed or in neutral.
not sure what it is the Iac isn’t moving when turning ignition.
Alex1743
May 28, 2020 04:32 AM
Ant1
Apr 2, 2016 05:41 AM
sam0329
Nov 24, 2013 10:50 PM
MrJuls
May 13, 2012 05:13 PM
